 Post subject: DOS MHDD Portable SATA Hard Drive Tester
PostPosted: July 16th, 2020, 1:26
I´m not the seller nor in any way connected to him, just an old timer dr guy (from 199x/200x) which used mhdd a lot back in the days and found this to be a curious device :)
I wonder if Dmitry got any $$$ for this ...
Product Description:
Handheld portable mobile HDD test machine, see the goods, test, desktop test, partition, grid data, ghost system, see current, change WD model, SN code, turntable, ST clear, automatic low-level scan, etc. Easy to carry, go out and see the goods, test, test on the counter, desktop test The machine has a short circuit automatic protection function. Perfect test 2.5; 3.5 hard disk Built-in battery life 3-5 hours Integrated function key One-button scanning Low grid WD clear, Seagate clear, health value test, SMART view keyboard operation can be partitioned GHOST system WD hard disk automatic repair. The store promises a one-year warranty on the machine (burning machine replacement within half a year!!!) Handheld portable mobile test machine, see the goods, test, desktop test, partition, grid data, ghost system, see current, change WD model, SN code, turntable, ST clear, automatic low-level scan, etc.
 Post subject: Re: DOS MHDD Portable SATA Hard Drive Tester
PostPosted: July 16th, 2020, 2:42
Press Shift F3
PostPosted: September 4th, 2020, 14:37
https://nl.aliexpress.com/item/40002379 ... 4097pdVXxf
www.disktuna.com - photo repair service
