 Post subject: Compatible PCB
PostPosted: October 17th, 2020, 6:20
I have hd Seagate Laptop Thin 500GB with dead PCB. And i have donor pcb with similiar series (seagate laptop thin 500GB), but the firmware series is different. The broken hd firmware is HPM2 and the hd donor is HPM6. Could i exchange the ROM to get the data back? Is it compatible?
Thank you
 Post subject: Re: Compatible PCB
PostPosted: October 18th, 2020, 19:15
you didnt mentioned the model of the drive. if the drive is not SED then you can do it , sure.
PostPosted: October 18th, 2020, 19:17
the firmware is on the platter , not in the rom.
PostPosted: October 19th, 2020, 3:18
Thank you for the answer
The model is same ST500LM000. But the firmware series is a bit different HPM2 and HPM6. Is it compatible?
PostPosted: October 19th, 2020, 3:29
Since you already have the board, just swap ROM and test.
ACELab partner
