 Post subject: Retrieve disk firmware
PostPosted: September 10th, 2021, 12:56
Hi all! Is there a tool available out there which lets your retrieve the disk controller as well as the disk drive firmware version? I'm talking about all kinds of drives - HDD, SDD and something that works across all vendors. I'm working on Windows. If there is an in-built utility, like WMI, which can retrieve the firmware, that would be ideal. Otherwise a 3rd party tool is fine as well. I only need to retrieve the firmware, not update it.
 Post subject: Re: Retrieve disk firmware
PostPosted: September 10th, 2021, 14:16
PC3000, MRT, SeDiv.
PostPosted: September 10th, 2021, 18:29
Those seem like repair tools. I'm looking for firmware retrieval tools. Also, something that is free. Open source is even better.
PostPosted: September 11th, 2021, 16:49
Access to firmware requires the use of vendor specific commands (VSC) which are not publicly documented. Moreover, firmware is modularised, so it's not just a matter of dumping a single binary image.
Go to the HDD Guru Files area and download some examples.
https://files.hddguru.com/download/PC-3000-UDMA%20Support/
Users browsing this forum: No registered users and 69 guests
