Sheered magnet screws
http://forum.hddguru.com/viewtopic.php?f=9&t=21871
Author:  hotmuon [ January 27th, 2012, 21:41 ]
Post subject:  Sheered magnet screws
Check this out. The screws sheered right off. I was wondering what that rattling was. :)
Author:  einstein9 [ January 28th, 2012, 3:50 ]
Post subject:  Re: Sheered magnet screws
S.A. :cry: :cry:
Author:  guru [ January 28th, 2012, 5:19 ]
Crap WD
Author:  Vulcan [ January 28th, 2012, 7:31 ]
Amazing... :( Was that caused by the VCM hitting the end stops repeatedly? Or had the user opened the drive before, and caused that damage themselves?
Author:  hotmuon [ January 28th, 2012, 22:00 ]
The drive was unopened. I picked it up and I could hear a clunking inside. This was of the era of drives sealed with metalized tape. The base of the drive must have been made with the powdered metal process which is notorious for having weak points. I'll have to do more research on the manufacturing processes used.
Author:  Vulcan [ January 29th, 2012, 7:49 ]
That's interesting - thanks!
Author:  hotmuon [ January 31st, 2012, 22:02 ]
After looking at the drive again I think the aluminum was cast in some method. I'm thinking die cast.
Author:  guru [ February 2nd, 2012, 13:24 ]
@Vulcan,
I have seen this exact problem over the years. I think it was a weak weld point
Author:  Vulcan [ February 4th, 2012, 13:44 ]
@guru,
Thanks for explaining - having those loose parts inside can't be good! :shock:
