Quiz time!
http://forum.hddguru.com/viewtopic.php?f=9&t=32823
Author:  pcimage [ January 29th, 2016, 16:04 ]
Post subject:  Quiz time!
In as few questions as possible, how did I get a near perfect clone of this drive? :-)
Author:  pcimage [ January 29th, 2016, 16:35 ]
Post subject:  Re: Quiz time!
Pros only get one shot! :-)
Author:  pclab [ January 30th, 2016, 13:47 ]
Before it fail :mrgreen:
Author:  LarrySabo [ January 30th, 2016, 14:06 ]
:lol:
Author:  Spildit [ January 30th, 2016, 14:10 ]
- Drive depoped at factory, no data on the damaged platter.
- Drive was empty or zero filled, a clone of an identical 0-filled or new drive would be the same as the drive with no data to start with.
- There was an image/backup available of the drive made some moments prior from it failing.
- Drive was on RAID 1 array (mirror) or any other redundant RAID array and the other drives survived so RAID array could be rebuild.
- Drive was under some sort of cloud copy software that back up on the fly to the cloud.
- Damaged platter didn't contain any data. Drive could be new and have just a few files that were stored on the other platters.
- Drive died at the end of a DDI/PC-3000 DE cloning process.
- Time machine.
- Erwin Schrödinger Quantum theory - You place the hard drive inside a box and the observer determines (decided) if the drive is broken or not. If you keep the box closed then the drive is good and broken at the same time :D :D :D
Author:  unknown [ January 30th, 2016, 19:31 ]
Is it WD?
Author:  microsoftengineer [ January 31st, 2016, 5:13 ]
Yes it is WD :wink: .
Author:  MindMergepk [ January 31st, 2016, 6:05 ]
+1
- Drive contains less data and last used sector was before the first scratch from inside out.
Author:  pcimage [ January 31st, 2016, 6:56 ]
Yep, top platter surface unused. De-popped at factory!
One very lucky lady got all her family photos back! :-)
Author:  MindMergepk [ January 31st, 2016, 7:22 ]
yes lucky :lol:
Author:  pclab [ January 31st, 2016, 17:04 ]
Damn...
WD refurbish a drive that shows this kind of scratches and put it back on business??
I wonder why they fail... :shock:
Author:  fzabkar [ January 31st, 2016, 17:20 ]
pclab wrote:
Damn...
What?
Author:  digisupport [ February 1st, 2016, 2:12 ]
Lucky client Sean,
I do not think that these damages left the factory, a later crash is the cause.
Your client made a superior choice in you, could imagine others would have rejected this case after lifting the lid.
Have seen it before that 1 or 2 heads are not used, if the failed qc or simply downgraded to lower capacity i can only guess.
Author:  fzabkar [ February 1st, 2016, 2:18 ]
I have seen one case at Tom's Hardware (?) where a 500GB (on the label) WD drive benchmarked like a 3-head 750GB drive that had been shortstroked.
Author:  fzabkar [ February 1st, 2016, 2:25 ]
If the drive had left the factory in a crashed state with the affected surface disabled, then the whole platter would have been reduced to glass or shiny metal in very short time.
Author:  pcimage [ February 1st, 2016, 4:13 ]
The drive had been dropped.
Author:  pclab [ February 1st, 2016, 4:53 ]
And only the top platter was damage?
No other problems?
If so, why did WD depoped that head? Some kind of problem was detected there....
