Truly professional method!
http://forum.hddguru.com/viewtopic.php?f=9&t=40578
Author:  buk4a [ November 9th, 2020, 3:20 ]
Post subject:  Truly professional method!
This is truly professional extraction of Data from HDD Israeli method. 8) :D
Author:  pepe [ November 9th, 2020, 17:34 ]
Post subject:  Re: Truly professional method!
Yes, it is always important to precisely identify the problem and find the proper tool for handling it. That's what a pro differs from DIY :P
Author:  sourcerer [ November 23rd, 2020, 6:53 ]
This does not look like a good idea to me, the ballistic dust will likely de-certify your cleanroom!
Author:  abolibibelot [ December 9th, 2020, 15:21 ]
Normally you don't have to actually use the gun, only act like you intend to use it and you really really mean it with a really really mean voice.
"WHERE ARE THE BYTES?!?"
A cleaner DIY method courtesy of Jack Bauer :
“Russians didn't have hi-tech equipment, so they kinda had to make do with what was around. Sort of like what I'm doin' right now. You probably don't think I could force this towel down your throat. But trust me, I can. All the way. Except I hold onto this one little bit at the end. When your stomach starts to digest it... I pull it out, taking your stomach lining with it. Most people, they take about a week to die. It's very painful.”
