Post new topic Reply to topic  [ 297 posts ]  Go to page 1, 2, 3, 4, 5 ... 15  Next
 Post subject: WD10TMVV
PostPosted: June 26th, 2010, 12:43
Is there an adapter for this drive?
 Post subject: Re: WD10TMVV
PostPosted: June 26th, 2010, 14:02
no
Data Recovery Ireland
PostPosted: June 26th, 2010, 14:27
So Find Another PCB??
PostPosted: June 26th, 2010, 14:51
Sorry - mind-reading is not my forte.
What's the problem with the drive? What are you trying to do?
http://www.datasaversllc.com
PostPosted: June 26th, 2010, 14:56
Trying To Recover Data Drive is Not Recognized through USB
PostPosted: June 26th, 2010, 15:01
oh one of those. Send it to a pro
PostPosted: June 26th, 2010, 15:18
Is the drive clicking? Trying to help you is too much work . . .
PostPosted: June 26th, 2010, 15:20
Frank = fzabkar (the knight in shining armour around this place)
What's that smell?....sniff sniff.......Is it burning martyr?
PostPosted: June 26th, 2010, 15:22
I was just hoping to find an adapter? or the name of an adapter? Or possible a different PCB to use on this drive.
PostPosted: June 26th, 2010, 15:38
There is no adapter available.
A different PCB will not work.
It's probably encrypted with WD Smartware which further complicates the issue.
You will need pro assistance for this.
PostPosted: June 27th, 2010, 19:17
I'm not a DR guy, but if you can upload detailed photos of both sides of the PCB, I should be able to identify the SATA Tx/Rx signal pairs for you. Then you will be able to adapt a SATA cable to bypass the USB bridge chip on the PCB.
Having said that, you really haven't provided any information other than that the drive cannot be detected via USB.
Does the drive spin up, or attempt to spin up? Any buzzing, vibration?
If using Windows, can you see any device in Device Manager, Disk Management?
Can you detect the enclosure using Microsoft's UVCView?
http://www.users.on.net/~fzabkar/USB_ID ... ew.x86.exe
Is there any 5V power getting to the PCB? Can you measure any voltages (2.5V, 3.3V ???) at any of the pins of the 12-pin header?
Can you see any cracks around the USB connector? WD users frequently report intermittent USB connections.
Is the bridge chip an Initio INIC-1607E? If so, then it has 128 bit AES encryption which may make your job difficult, if not impossible.
If you suspect that the bridge chip may be dead, disconnect the data or clock signal to the associated 8-pin serial EEPROM chip. The bridge chip should then identify itself with its own Product ID (INIC-1607E) and Vendor ID (Initio) rather than the one in the EEPROM.
PostPosted: June 30th, 2010, 14:23
I Dont think it the USB I can hear the drive clicking slightly.
PostPosted: June 30th, 2010, 14:30
In this case if you hear drvie clicking slightly then it can be SA damage to some mods or heads on it. You will need pro help on this one it is not a fix for you on it. Sorry to say this one but if you want data back then find a company that can help you out on this one.
Iorana Haraharaini
PostPosted: July 12th, 2010, 1:02
Sir ,
first do not get disheartened by these professionals .They just come here to understand cases and standard reply is send to a pro .Pro means if someone has a issue at XYZ country the pro will find is Pro Friend in that country and refer the client to him .Its just gaining knowledge and making money thats all i would say since the time i have joined HDDGURU by these select 10+ people .Anyway Back To the Question I have this drive and i would be doing something in this regard today and post you my progress .I think the drive has some bad sectors and hence USB Interface is posing issues in this .My plan is as under
I will provide the necessary voltages to the drive either via USB [ After Disconnecting the Signals From The Same ] and they Get the signal Out directly To the SATA Interface in my DR computer Motherboard .then clone it and recover the data .Lets See What Happens .
PostPosted: July 12th, 2010, 3:58
Well ,
Just for a Heads Up ,Drive Has INIC-1607E Bridge Controller IC SATA to USB with AES 48pin LQFP .this Basically Means Either We Find the Pin Diagram Of the 12 Header Or If We Try and bypass the INIO CTRL Might Be It Has Already Encrypted The Drive and Its a fruitless excercise Or Might Be If AES is Not Been Used It Works ,God Know Checking Still .
PostPosted: July 12th, 2010, 21:07
Hello all,
This interests me. The could you PM photos of both sides of the board.
HWHacker
Smiles
PostPosted: July 15th, 2010, 11:08
HWHacker & Amarbir
here is the images, i just got one HD to try
i was wondering about this subject results really
and thnx
PostPosted: July 15th, 2010, 13:47
einstein9 wrote:
HWHacker & Amarbir
and thnx
Lol ,
this will not solve it ,i am working on a solution should be able to finish this case this weekend
PostPosted: July 15th, 2010, 17:57
Good photos, but a bit hard to see through the HDA. (Putting on XRay glasses) oh yes much better. :wink:
One more photo please. :wink:
HWHacker
Smiles
PostPosted: July 16th, 2010, 4:13
Amarbir
am wondering about the solution for this case, because i found 1T the one i sent here for testing.
good luck
Users browsing this forum: Google [Bot], Google Adsense [Bot], gps31 and 41 guests
