Unless you are good with a test meter and know what those resistance/transistor/diode whatever things are you should get some professional help, um... yes the hard drive PCB need professional help. To many things can be wrong.
From your photos it would look like the power input inductors got fried. Now this does not usually happen on its own. Some other component probably fried and drew sufficient current to burn the inductor. If you jumper across the inductor and power it up for 2 and ONLY 2 seconds you could probably feel the heat on the dead component. Just maybe. OK, then what. So start looking for a donor PCB and a shop to swap ROM.
Lots of Luck.
![Sad :(](./images/smilies/icon_sad.gif)
