Forum rules
No new topics are allowed in this forum. Please use other forums to create topics.
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: HDD from inside: Main parts
PostPosted: September 15th, 2010, 5:38
it says im forbidden to see documents on here :(
PostPosted: September 15th, 2010, 6:09
Ive checked the last 3 links are ok
Free Solutions
PostPosted: November 26th, 2010, 11:48
Hi ,
I would like to know if I can use this program to format my Ipod.
I'm having several problems and none of the apple sugestions fixed it.
PostPosted: February 8th, 2011, 18:12
please help me
I have a problem
i format my hard disk sata in low level for accident
and now not recognized
and need reinstall Operating System
PostPosted: February 8th, 2011, 18:26
If using Windows, have you initialised the drive in Disk Management?
BTW, it would have been better to have started your own thread.
PostPosted: February 25th, 2011, 19:31
very helpful thanks !
PostPosted: February 26th, 2011, 4:35
Thanks Doomer,Very usefull material!
PostPosted: February 16th, 2012, 2:25
For newbie like me...that artikel to usefull for me.
Great shares Doomer...
PostPosted: March 25th, 2012, 1:09
Thank you A7med89, I was looking for the correct URL.
PostPosted: May 31st, 2012, 14:42
Thanks for the link, very helpful!!! :mrgreen:
PostPosted: September 22nd, 2012, 11:56
Thanks doomer for usefull tips , i am new in data recovery
PostPosted: November 9th, 2012, 13:04
I have a strong desire to Engineer a tool, for all of us, to incorporate firmware access/recovery for these hard drives as I see it pointless to "rent-a-hdd" when it suddenly crashes on you and you're faced with recovery fees just to have another one crash on you... so on..
thus far I..
designed my own RS-232 to TTL solution shown here (nvm magicHack) .
The chip you see is the serial Firmware chip, awaiting r.E. (RevEng[e]) from me. This is pretty straight forward, functional and is getting me closer to retrieving over 2+T of software on my backup drive!
This is the actual controller board. Luckily, SeaGal engineered it to "stand-alone" without any dampers or pullup/downs in circuit so this was possible without destruct.
Eventually while intercepting the SATA protocol I'll closely study the firmware, memory stack and commands from the MCU (tips welcomed guys) . Have a look:
Their debugger equipped bootstrap code is called "Yeti Boot", dating back to 2007! seemingly beautiful flexible code for the Barracuda ST31000528AS stuff and others but like I told the Seagalte crew "I just want my data back, you didn't have to start a war.."
The HDD TTL access - You should have a dongle with a connector that will fit a 2mm pitch, 4 node connector (Ex: IDE notebook drive). Connectors are labeled: [ TX|RX|GND|N/C ], hard drive writing faced up or just remember "TRiG" and go with the Max232 family & follow the datasheets.. enjoy; interceptors circuits are next. ~UART "I don't believe in luck; I believe in Precision."
PostPosted: November 9th, 2012, 14:05
UART wrote:
thus far I..
nowhere :)
But good luck
https://www.linkedin.com/in/artemrubtsov/
PostPosted: November 10th, 2012, 0:18
Doomer wrote:
UART wrote:
thus far I..
nowhere :)
But good luck
Yeah, won't you believe it?? :lol: however It's pretty straight-forward. Can't get a hold of a manual so we'll just create our own.
The MCU has 10+I/O ports DAC/ADC interface?? with most likely a JTAG or similar interface which may be enabled during this stage... I'll find out if so.
It shouldn't be all that hard. I know our .ru friends been at it diligently, making progress but I'll post my stuff, schematics, datasheets etc for the time being for now here's the Schematic to my RS-232 to TTL Dongle:
~UART "Oh that's the problem! Both back wheels are on backwards, pulling against each other."
PostPosted: December 26th, 2012, 16:57
Thanks Doomer, that was awesome.
PostPosted: April 18th, 2013, 7:26
UART wrote:
Doomer wrote:
UART wrote:
thus far I..
nowhere :)
But good luck
so how was it? do you succeed?
PostPosted: November 29th, 2013, 12:44
found another paper about hdd parts: Hard Disk Drives
PostPosted: March 4th, 2014, 16:41
Thank you Doomer, nice work.
PostPosted: April 6th, 2015, 13:10
https://www.youtube.com/watch?v=AfmTaOJMoUk
PostPosted: April 7th, 2015, 0:15
<null>
