Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: Atola Imager fail to many issues
PostPosted: May 30th, 2011, 4:52
Craig,
Thank you for the screenshots.
At the bottom right you can see four buttons. First three control Source HDD power (ON/OFF/CYCLE); the last one allows to power off the target drive. It was like that for a very long time; we did not change anything. You can downgrade to any previous version and verify that.
We plan to add Target Power ON button in the upcoming release.
Media recovery is not for data recovery; it is primarily for R&D (to be used together with Generate Bad Sectors). It can also be used to repair a few bad sectors on a hard drive without any data. It specifically says to not to use it for data recovery (see attached screenshot). Please do not use this feature in relation to any data recovery case; use imaging instead. If imaging does not work then Media Recovery won't be of any help.
Dmitry
PostPosted: May 30th, 2011, 5:06
yes i notice your screen is different from mine
im still on version 1.46.29611
so i got a older version still
not sure what happened as i did the full update.
when it asked for you to hold down the yellow source button on the drive
so it never updated at all :(
thanks
PostPosted: May 30th, 2011, 5:33
Wow, that version is 1 year old. Current version is 2.1.
Try installing the latest 2.1 update again. Let me know if you run into any issue updating.
Dmitry
PostPosted: May 30th, 2011, 5:46
working fine now it updated.
going to pay for new updates this week.
thank you for all your hard work
dmitry
PostPosted: May 30th, 2011, 5:49
You're welcome!
If you run into any issue in the future, just let me know.
Dmitry
PostPosted: December 15th, 2013, 21:41
Are you saying Imager or Bandura? I had the Target power go south on the Bandura. However, it was simply a surface mount capacitor that died, when investigated.
Jason Davies, TechRx Inc.
techrxgb.com
920.884.1195
PostPosted: December 16th, 2013, 1:21
this is a old post everything is finer with the atola no issues
Users browsing this forum: No registered users and 0 guests
