 Post subject: USB M I C R O S C O P E
PostPosted: February 27th, 2011, 19:42
if anybody using this microscope for checking pcb, please let me know the results are satisfied,
thanks.
please check the link
http://www.veho-uk.com/main/shop_detail.aspx?article=40
thanks to all
 Post subject: Re: USB M I C R O S C O P E
PostPosted: February 27th, 2011, 19:51
I have that microscope but dont use it to check PCB's. More like heads and platters for damage. It's ok for its price but dont expect a clear picture. It's really a 25x or 200x with digital 400x. So don't be fooled.
PostPosted: February 28th, 2011, 6:37
i guess no one will use it for pcb checking
high res. image with good camera will do the job more better/cheaper than this
pcb checking most of use good multimeter not more than this with good diagnose and know the problem and what to check 1st. if the pcb is dead or faulty.
PostPosted: March 1st, 2011, 1:13
hi,
i am use this kind of tools for check the PCB, pen drive etc..... please contact me by email or skype if want to see result. :)
data recovery service[/b]
PostPosted: June 30th, 2013, 4:18
i'm using it only for chip swap on pcb
PostPosted: June 30th, 2013, 5:55
Did buy one....used it for a very short while....ended up getting a proper stereo microscope, much easier to use for working and especially when re soldering...... but for taking hi magnification pics it's ok.... the stand is generally awkward at best, and you'll find yourself weighing it or taping it down and forever fiddling with the focus to get a clear pic.....
East Anglian Data Recovery Services
http://www.eadr.co.uk
"If it's your only copy - then it's not a backup!"
PostPosted: June 30th, 2013, 8:22
Online
I have the 1.3MPx (mega pixel) version of [url]this[/url] one and have been very satisfied with it. The one in the link is 5MPx. There's a sample picture of a DC jack bad solder joint on my website, if interested.
PostPosted: July 19th, 2013, 18:07
sir
i am interested, give me more details
PostPosted: July 19th, 2013, 19:35
Online
Oops! Did a poor job at providing that URL. Here it is.
PostPosted: July 28th, 2013, 12:59
I use a similar microscope for soldering check on small SMD devices pins, example SMOOTH chips pins.
http://www.drivestar.biz/usb-digital-mi ... nh2venbt51
But usually i use this to check pins on smd devices:
http://www.drivestar.biz/double-eye-gla ... nh2venbt51
PostPosted: August 3rd, 2013, 11:57
THANKS
THANKS
PostPosted: August 3rd, 2013, 12:46
I just got a pair of these, well similar ones. With yours do you have to bend don and be very close to the job? I need to get within a CM or 2 for it to focus. quite hard to work like that.
PostPosted: August 3rd, 2013, 15:04
Yes, you need to be very close with it.
Microscopes works like that as i know.
I use it only to do alignment of IC with a lot of pins to pcb pad, then i move the microscope away to do soldering, after i check my job result again with the microscope.
PostPosted: August 3rd, 2013, 16:54
Online
I use a headband magnifier that doesn't interfere with my glasses, and it has a flip-down lens for additional magnification. Looks just like this one. At the higher magnification, I need to be about 6" (15cm) from the object--not to bad for SMD work. Check out the video on that page.
PostPosted: August 3rd, 2013, 17:18
I have also glassees similat to this, watch the video:
http://www.youtube.com/watch?v=-Qocr3dCv48
The good thing is that they have 2 good bright lights :D
The negative thing is that i must be close 5 cm, not enough space to work... :cry:
I must choose when to look with those glasses and when to work with soldering iron (without glasses)
Users browsing this forum: No registered users and 0 guests
