This guy is a liar he just change his words for only $300 and wasted my time almost 1 hour and he did not give me access of his system after hearing complete formula of this problem. and I were stuck and feel bad
you people better decide here is the chat. I will never forgive him.
[5/22/2014 12:39:23 PM] Muhammad Ali: is it spin down problem?
[5/22/2014 12:39:39 PM] Jared Palmer: yeah
[5/22/2014 12:39:50 PM] Muhammad Ali: how many head?
[5/22/2014 12:39:51 PM] Jared Palmer: but seems to read modules fine after hotswap
[5/22/2014 12:39:54 PM] Jared Palmer: 6 heads
[5/22/2014 12:40:04 PM] Jared Palmer: 2 3 4 5 6 7
[5/22/2014 12:40:05 PM] Jared Palmer: is the map
[5/22/2014 12:40:20 PM] Muhammad Ali: do you have UDMA + DE?
[5/22/2014 12:40:34 PM] Jared Palmer: yeah
[5/22/2014 12:40:50 PM] Jared Palmer: If you can figure this one out it's worth a few $$$
[5/22/2014 12:40:55 PM] Muhammad Ali: is it 2.5 or 3.5 ?
[5/22/2014 12:41:00 PM] Jared Palmer: 3.5
[5/22/2014 12:41:09 PM] Muhammad Ali: ok good i have a formula.
[5/22/2014 12:41:18 PM] Muhammad Ali: i can try it right now.
[5/22/2014 12:41:29 PM] Jared Palmer: sure
[5/22/2014 12:41:34 PM] Jared Palmer: you use teamviewer?
[5/22/2014 12:41:42 PM] Muhammad Ali: prepare hdd with its original PCB.
[5/22/2014 12:41:46 PM] Muhammad Ali: yeah
[5/22/2014 12:41:55 PM] Jared Palmer: what version tv you use?
[5/22/2014 12:42:10 PM] Muhammad Ali: and just back after get some drinks.
[5/22/2014 12:42:12 PM] Muhammad Ali: any
[5/22/2014 12:42:27 PM] Muhammad Ali: just give me ID and pass.
[5/22/2014 12:43:16 PM] Jared Palmer: ok, just give me 5 min
[5/22/2014 12:43:30 PM] Jared Palmer: I'm finishing up one other thing on my pc-3000
[5/22/2014 12:46:02 PM] Jared Palmer: ok, I'm using TV version 8
[5/22/2014 12:46:09 PM] Jared Palmer: ID 292 191 675
[5/22/2014 12:46:14 PM] Jared Palmer: Pass 7030
[5/22/2014 12:46:25 PM] Jared Palmer: drive is connected on channel 0
[5/22/2014 12:46:43 PM] Muhammad Ali: how much you give me for this..
[5/22/2014 12:47:03 PM] Muhammad Ali: and how about the formula i am going to share!
[5/22/2014 12:47:09 PM] Jared Palmer: if it's a quick fix $200 as soon as my customer pays
[5/22/2014 12:47:18 PM] Jared Palmer: if it takes a while more
[5/22/2014 12:47:28 PM] Muhammad Ali: no its not work.
[5/22/2014 12:47:54 PM] Muhammad Ali: minimum $800 400 yours and 400 mine.
[5/22/2014 12:48:08 PM] Jared Palmer: I only quoted the customer $500
[5/22/2014 12:48:20 PM] Jared Palmer: assuming that it's just a SA issue
[5/22/2014 12:48:32 PM] Muhammad Ali: I am going tu share head testing formula.
[5/22/2014 12:48:45 PM] Muhammad Ali: no you are wroge.
[5/22/2014 12:48:52 PM] Muhammad Ali: it is spin down?
[5/22/2014 12:49:12 PM] Jared Palmer: yeah, but even the donor spins down after I copied the tracks over
[5/22/2014 12:49:40 PM] Jared Palmer: had to enter kernel to rewrite the orig donor tracks
[5/22/2014 12:49:40 PM] Muhammad Ali: ok go ahead... i hope to get better relation with you.
[5/22/2014 12:49:57 PM] Muhammad Ali: just back the hdd to its original PCB.
[5/22/2014 12:50:07 PM] Jared Palmer: how about $300
[5/22/2014 12:50:12 PM] Jared Palmer: that sound fair?
[5/22/2014 12:51:13 PM] Muhammad Ali: that's not good at all Jard i am going to share disabling damaged head formula. without head swap
[5/22/2014 12:51:40 PM] Jared Palmer: if you're just talking about changing headmap in RAM I've already tried that
[5/22/2014 12:52:16 PM] Muhammad Ali: so you know it... so what happend?
[5/22/2014 12:52:27 PM] Jared Palmer: same result
[5/22/2014 12:53:03 PM] Muhammad Ali: ok let me see then i have to check on my way
[5/22/2014 12:53:04 PM] Muhammad Ali: ok!
[5/22/2014 12:54:20 PM] Muhammad Ali: ??
[5/22/2014 12:56:26 PM] Muhammad Ali: what happend?? jard..
[5/22/2014 12:56:50 PM] Jared Palmer: hold on, sorry, something came up...
[5/22/2014 12:59:41 PM] Jared Palmer: might have to come back to this another day. I gotta take care of something now, and the customer isn't in a hurry anyway. Just pictures on the drive
[5/22/2014 1:00:41 PM] Muhammad Ali: what you mean?
[5/22/2014 1:00:52 PM] Muhammad Ali: check tommorow?
[5/22/2014 1:01:07 PM] Jared Palmer: probably Monday. I'm not working tomorrow.
[5/22/2014 1:01:29 PM] Muhammad Ali: before 5 min you ready to check..
[5/22/2014 1:02:31 PM] Jared Palmer: really can't. I have to go take care of something.
[5/22/2014 1:03:16 PM] Muhammad Ali: I am not a kid Jard better luck what i have advice... you.!
[5/22/2014 1:17:49 PM] Muhammad Ali: Jard money is no problem but your changing words really hurt i can't believe this.
[5/22/2014 1:18:18 PM] Jared Palmer: I don't think I understand what you're talking about...
[5/22/2014 1:18:42 PM] Jared Palmer:
[b]I'm saying that something completely unrelated to this project came up and now I have to deal with that instead.[/b]
[5/22/2014 1:18:56 PM] Jared Palmer: I'll be back to this project later. Probably Monday
[5/22/2014 1:19:33 PM] Muhammad Ali: are you try head map in RAM? speak truth?
[5/22/2014 1:19:39 PM] Jared Palmer: yes
[5/22/2014 1:19:57 PM] Jared Palmer: but I really don't have time to work on this now.. got another emergency on my hands
[5/22/2014 1:21:04 PM] Muhammad Ali: ok jared as you wish..
[5/22/2014 1:21:17 PM] Muhammad Ali: i can't look this case again... if even you say..
[5/22/2014 1:23:15 PM] Muhammad Ali: you get the detection Jared with head map formula!!
[5/22/2014 1:23:18 PM] Muhammad Ali: am i right?
[5/22/2014 1:24:24 PM] Jared Palmer: no, like I said I had already tried that with the same result
[5/22/2014 1:25:06 PM] Jared Palmer: I'm thinking it might be a compound issue. I did notice some corrosion on the PCB, so I'm thinking that perhaps the whole thing got wet and it's more than one issue.
[5/22/2014 1:39:02 PM] Muhammad Ali: i can't believe this..
[5/22/2014 1:39:08 PM] Muhammad Ali: then why you wast my all time..
[5/22/2014 1:39:10 PM] Muhammad Ali: !!!
[5/22/2014 1:39:25 PM] Muhammad Ali: i am just stuck because of you..
[5/22/2014 1:40:29 PM] Jared Palmer: I'm not wasting your time. I asked a question on a forum earlier today which you responded to. And right now I don't have time, I'm busy with another project
[5/22/2014 2:09:37 PM] Muhammad Ali: I'm saying that something completely unrelated to this project came up and now I have to deal with that instead. what that mean Jared?
[5/22/2014 2:15:15 PM] Muhammad Ali: ok Jared i am going but you missed the greate formula what i said is uncomplete..
[5/22/2014 2:15:29 PM] Muhammad Ali: so better keep your words truth
[5/22/2014 2:18:27 PM] Muhammad Ali: now get a block from me.
[quote="data-medics"]I'm working on a Kermit family drive wd10eavs-00d7b1. The drive can't read it's SA SPT even after ldr upload. The drive just tries to read SA several times then shuts down.
