 Post subject: Toshiba HDD Under Construction
PostPosted: February 4th, 2015, 3:29
Never saw this message in toshiba, and really looks funny here
but will ID @ the end
hehehe
anyone saw this before?
 Post subject: Re: Toshiba HDD Under Construction
PostPosted: February 4th, 2015, 3:45
Is the pcb original?
Does the s/n match the drive label?
PostPosted: February 4th, 2015, 4:01
SN match org. pcb Yes...
PostPosted: February 4th, 2015, 4:12
FWIW, I see one forum post where the drive's owner states that his drive doesn't appear to be spinning. That would suggest a PCB fault. Does the PCB ID the same way on its own?
PostPosted: February 4th, 2015, 4:21
pcb is fine, spins and works and ID
but before the ID am getting this msg temp. then it goes well
PostPosted: February 4th, 2015, 9:50
I suspect that this is a prgoramming/translation error with PC3K and not an actual message from the hard drive itself.
SSD Data Recovery
PostPosted: February 4th, 2015, 13:32
No, it's a real error.
http://forums.toshiba.com/t5/General-Tr ... d-p/351462
PostPosted: February 4th, 2015, 13:48
Weird.
SSD Data Recovery
PostPosted: February 4th, 2015, 16:26
I notice that "Franz" states that he "can't even feel the drive spin", so that's why I asked einstein9 if he could reproduce the error with the PCB on its own. ISTM that a reference to construction would suggest that the drive may be repairing damaged firmware, either on the PCB or on the platters. However, I only have a vague idea as to how and where Toshiba drives store their firmware modules. Alternatively, could the drive be thinking that it is in manufacturing mode???
PostPosted: February 4th, 2015, 22:05
these are of ROM
does not work the heads.
Offset      0  1  2  3  4  5  6  7   8  9  A  B  C  D  E  F
00021070   02 07 00 00 4C 00 40 00  F8 01 00 00 EB 74 0B 7F       L @ ø   ët
00021080   23 61 00 74 00 00 23 61  3F 00 00 00 00 00 00 00   #a t  #a?
00021090   00 00 00 00 44 52 49 56  45 20 55 4E 44 45 52 20       DRIVE UNDER
000210A0   43 4F 4E 53 54 52 55 43  54 49 4F 4E 20 20 20 20   CONSTRUCTION
000210B0   20 20 20 20 20 20 20 20  20 20 20 20 FF FF FF FF               ÿÿÿÿ
