 Post subject: Quiz time!
PostPosted: January 29th, 2016, 16:04
In as few questions as possible, how did I get a near perfect clone of this drive? :-)
 Post subject: Re: Quiz time!
PostPosted: January 29th, 2016, 16:35
Pros only get one shot! :-)
PostPosted: January 30th, 2016, 13:47
Before it fail :mrgreen:
http://www.pclab.com.pt facebook.com/PCLAB.Assistencia.Tecnica
ACELab partner
PostPosted: January 30th, 2016, 14:06
:lol:
PostPosted: January 30th, 2016, 14:10
- Drive depoped at factory, no data on the damaged platter.
- Drive was empty or zero filled, a clone of an identical 0-filled or new drive would be the same as the drive with no data to start with.
- There was an image/backup available of the drive made some moments prior from it failing.
- Drive was on RAID 1 array (mirror) or any other redundant RAID array and the other drives survived so RAID array could be rebuild.
- Drive was under some sort of cloud copy software that back up on the fly to the cloud.
- Damaged platter didn't contain any data. Drive could be new and have just a few files that were stored on the other platters.
- Drive died at the end of a DDI/PC-3000 DE cloning process.
- Time machine.
- Erwin Schrödinger Quantum theory - You place the hard drive inside a box and the observer determines (decided) if the drive is broken or not. If you keep the box closed then the drive is good and broken at the same time :D :D :D
PostPosted: January 30th, 2016, 19:31
Is it WD?
PostPosted: January 31st, 2016, 5:13
Yes it is WD :wink: .
PostPosted: January 31st, 2016, 6:05
+1
- Drive contains less data and last used sector was before the first scratch from inside out.
Data Recovery Pakistan
PostPosted: January 31st, 2016, 6:56
Yep, top platter surface unused. De-popped at factory!
One very lucky lady got all her family photos back! :-)
PostPosted: January 31st, 2016, 7:22
yes lucky :lol:
PostPosted: January 31st, 2016, 17:04
Damn...
WD refurbish a drive that shows this kind of scratches and put it back on business??
I wonder why they fail... :shock:
ACELab partner
PostPosted: January 31st, 2016, 17:20
pclab wrote:
Damn...
What?
PostPosted: February 1st, 2016, 2:12
Lucky client Sean,
I do not think that these damages left the factory, a later crash is the cause.
Your client made a superior choice in you, could imagine others would have rejected this case after lifting the lid.
Have seen it before that 1 or 2 heads are not used, if the failed qc or simply downgraded to lower capacity i can only guess.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: February 1st, 2016, 2:18
I have seen one case at Tom's Hardware (?) where a 500GB (on the label) WD drive benchmarked like a 3-head 750GB drive that had been shortstroked.
PostPosted: February 1st, 2016, 2:25
If the drive had left the factory in a crashed state with the affected surface disabled, then the whole platter would have been reduced to glass or shiny metal in very short time.
PostPosted: February 1st, 2016, 4:13
The drive had been dropped.
PostPosted: February 1st, 2016, 4:53
And only the top platter was damage?
No other problems?
If so, why did WD depoped that head? Some kind of problem was detected there....
ACELab partner
Users browsing this forum: No registered users and 0 guests
