 Post subject: HDD brick thanks to DFLWD...
PostPosted: May 5th, 2016, 21:49
To any kind soul that can help me repair the 4 HDD that is bricked...
I am a total newbie in this software, but I tried to read the ROM of the DFL tool on 4 western digital hard disk and the device said "ROM read success", so when I tried to write the ROM that I have just read out from the tool, I was being prompt with "ROM deep test error" (or something like that) and something about the "ROM being of a different length , would you like to force write" and I just ignored the warning and proceed to write the ROM. Now whenever I plug the HDD into the DFL tool, the 2 lights that are flashing are "DRD" and "ERR", the HDD is not even spinning anymore, please help SOS...
 Post subject: Re: HDD brick thanks to DFLWD...
PostPosted: May 5th, 2016, 23:00
Q: why have you tried to read and write in the first place ?
Q: what's the initial problem with the drive ?
Q: do you have any other tool beside DFL ? (PC3K, external programmer)
Q: can DFL access the PCB using terminal ?
Q: would you mind upload the ROM here ?
PostPosted: May 5th, 2016, 23:22
If drives are WD you can do a hotswap and rebuild ROM from SA. Look in DFL forum, there should be a manual how to do that. Do not try that on client drives but two known fully working ones for practice first.
Do not ignore warnings in DR-tools, most time they are right and you can trash a drive with them fast (ie defect list erase, ...).
Best regards,
PostPosted: May 6th, 2016, 14:18
Did you read DLF WDII manual before you start bricking hard drives?
What was problem with those WD's.
Sistrum Data Recovery
http://www.sistrum.mk/en
PostPosted: May 8th, 2016, 21:04
The WD HDD did not have any problem at the start until I tried writing its original ROM back to it.
ROM_WDC WD5000LPCX-00VHAT0.bin.txt [256 KiB]
Downloaded 1398 times
ROM_WDC WD2003FZEX-00Z4SA0.bin.txt [1 MiB]
Downloaded 1347 times
PostPosted: May 8th, 2016, 22:45
I really don't get it, if the drive didn't have any problem in the first place, why would you try to rewrite the ROM
I really hope it doesn't belong to a client
Regardless what is the 2 files (I.e. which one is the problematic) ?
PostPosted: May 9th, 2016, 2:42
Both ROM are problematic just from different HDD. I was just trying to explore the different features of the software.
PostPosted: May 9th, 2016, 3:54
I can't check your ROM now, but This ROM is the same ver. as your ROM_WDC WD5000LPCX-00VHAT0.bin.txt just transfer the adaptives
the question is if you have access to drive to flash another ROM I.e. using TTL or external programmer.
Regarding the other one - like I said - I can't check it now, and I wasn't able to find it either.
PostPosted: May 9th, 2016, 11:03
The code sections of each ROM are OK.
Searching for LDSCs and verifying PCMBlocks ...
LDSC   LDSC    PCMBLock       PCMBlk CS
Start  ID CS   Start - End     Exp/Act
00000  5A CD   00100 - 021EF  8F7D 8F7D   OK
00020  01 7E   021F0 - 04C18    4C   4C   OK
00040  02 D7   04C19 - 0BFB5    59   59   OK
00060  03 02   0BFB6 - 0C8CA    ED   ED   OK
00080  04 08   0C8CB - 0CAB7    CA   CA   OK
000A0  05 39   0CAB8 - 0CCC0    66   66   OK
000C0  06 73   0CCC1 - 1F325    D9   D9   OK
000E0  07 66   1F326 - 3CF3A    FF   FF   OK
00000  5A 95   00020 - 00FB1  E400 E400   OK
01000  01 6A   01120 - 03300    DE   DE   OK
01020  02 30   03301 - 03815    FB   FB   OK
01040  03 DF   03816 - 0C036    B1   B1   OK
01060  04 1B   0C037 - 0C6E3    57   57   OK
01080  05 52   0C6E4 - 0C8E4    B0   B0   OK
010A0  06 C6   0C8E5 - 0CAE9    15   15   OK
010C0  07 E4   0CAEA - 25166    39   39   OK
010E0  08 06   25167 - 4188B    A7   A7   OK
81000  01 6A   81120 - 83300    DE   DE   OK
81020  02 30   83301 - 83815    FB   FB   OK
81040  03 DB   83816 - 8C02E    83   83   OK
81060  04 0B   8C02F - 8C6D7    DB   DB   OK
81080  05 46   8C6D8 - 8C8D8    0A   0A   OK
810A0  06 BA   8C8D9 - 8CADD    6F   6F   OK
810C0  07 D4   8CADE - A5156    E1   E1   OK
810E0  08 F6   A5157 - C187B    A7   A7   OK
LDSC   = PM Loader Config String (32 bytes)
ID     = ID byte of LDSC (byte #0)
CS     = Checksum byte or word
PCMBlk = Program Code Memory Block
Exp    = Expected checksum for PCMBLock
Act    = Actual checksum for PCMBLock
