 Post subject: Identification problem coused by ROM contents
PostPosted: June 2nd, 2016, 3:09
Hi folks,,
I have cleint HDD WD3200BEVT-00ZCT0, it has a problem with orginal ROM, and ROM is embeded with MCU
So, I used another similar PCB, it's give me Identification problem coused by ROM contents
I can reach to SA, I make a backup for 102,103,105,107,109 by HDD doctor for WD, But Module 103 give me error, not because SA error but it's common failur to load module 103 in this family
I converte the name of module 103 from "ERR-0103" to "0103", and I tried to regenerate ROM using this ROM overlays,
it's give me complete regeneration ROM, but after that it's didn't configure correctlly
I apply that as I read it in one artical as below
"Mod 0103 is not a critical module for drive to work fine. It is used to recover lost ROM together with other modules 01xx.
You don't have to worry about this module.
In a map module in some brand new ROYL drives it stays as module should have length of 2 sectors - 1024 bytes, but inside 0103 mod it is signed as 1 sector -512 bytes that is why LENGTH ERROR occurres.
If You want to use 0103 module for example to regenerate ROM, all You need to do is just take err_0103.mod saved by HD Doctor and use any of hex editors to cut 512 bytes starting from offset 0200 (there should be only 00h or FFh bytes). After this You can save it as 0103.mod and You will have valid 0103 module .
But probably this module is NOT_INIT so it is worth and used for nothing. "
But without success, So How I can rebuild the correct rom by this ROM overlays??
Expect, the Unexpected
 Post subject: Re: Identification problem coused by ROM contents
PostPosted: June 2nd, 2016, 5:07
if you can't rebuild the ROM, try to identify ROM version from SA modules and get a copy from hddguru files or ask forum for the same version.
Data Recovery Pakistan
PostPosted: June 2nd, 2016, 7:06
ROM version is: 000800FA
I attached mod11, mod109
Mod11,109.rar [324.73 KiB]
Downloaded 538 times
PostPosted: June 2nd, 2016, 7:40
http://files.hddguru.com/index.php?acti ... ty/Denali&
PostPosted: June 2nd, 2016, 7:51
jermy wrote:
http://files.hddguru.com/index.php?action=view&filename=WD3200BEVT-60ZCT1-13.01A13-000800FA-WX20A9914674.rar&directory=PC-3000-UDMA%20Support/WDC%20Marvell%20family%20utility/Denali&
Thanks,,
I'll try it,
PostPosted: June 4th, 2016, 7:53
I try this ROM, But without success, it's give me the same symptoms "HDD stay Bussy and I can't reach to SA"
But, when I write foreign ROM it's give me Ready with Identification problem and I can reach to SA and make backup for All Module smoothly!
Are any member solve such that problme? it's strange case>>>
PostPosted: June 4th, 2016, 8:41
check RE-LO and G-List. If RE-LO have entries then apply slow fix by patching mod 02.
Check heads as well
PostPosted: June 6th, 2016, 4:40
after check, I thik the problme probably in head
So I will find donor HDD and make headswape
PostPosted: June 6th, 2016, 4:58
problem is with SA as well in my opinion.
you should try smart-hot-swap before swapping heads.
PostPosted: June 7th, 2016, 5:01
Ill try to make smart-hot-swap before swapping heads after I got it the donor.
PostPosted: August 2nd, 2016, 0:50
update:
I recoverd this HDD,, it was issue in firmeware module02..
PostPosted: August 4th, 2016, 3:40
Congratulations! Rewrite MOD02 to solve that?
cron
