 Post subject: Seagate Hard Disk Head replacement Matching
PostPosted: May 29th, 2016, 7:59
Recently I have purchased Hdds sea 7200.12/.11+p1 set from HDD Surgery. I have tried more than 15 hard disk with same model donor nothing successful. the tool is fine working
I have a clean Room too also I am very successfully replacing Heads for other brand (WD, Toshiba, Samsung) . I am clueless .
Kindly help me my email ssemmalar@gmail.com
Douglas Crowell
 Post subject: Re: Seagate Hard Disk Head replacement Matching
PostPosted: June 2nd, 2016, 7:07
Dear Sir,
According to our client's database we don't have you listed as our buyer.
Nor we have received even similar complaints about our Hdds sea 7200.12/.11+p1 set.
Are you sure that you bought our tool, and not some cheap copy which is prone to have lots of different kinds of malfunction?
Kind regards,
PostPosted: June 2nd, 2016, 17:31
Douglas Crowell
Well,
Seems Like a Fellow Countrymen Trying To Defame a Perfectly Working Tool .If 15 Donors Cannot Get Your Drive Operational Get Professional Help .Replacement of SINGLE PLATTER Hdd Is a Piece of Cake Atleast For Me And I Do Not See Any Reason Why Nikolas Tools Would Not Work .
PostPosted: June 3rd, 2016, 4:47
Hello sorry ALL
I am not blaming the tool, this is the best tool ever made. I have tested the tool with the working hard disk it is fine. only my problem is when I replace the head with head damaged hard disk same model, Firmware, Site code it is giving clicking sound. I don,t know the mistake.
Kindly help me. If any one have technical details kindly send me
my id is ssemmalar@gmail.com
PostPosted: June 3rd, 2016, 12:29
Hello sorry ALL
Well,
Which Place Are You From in India ? . We Are Based In Chandigarh
PostPosted: June 4th, 2016, 10:01
Are you sure you have a suitable donor? Are you sure that it is a head issue and not a firmware issue?
RAID Data Recovery
PostPosted: June 4th, 2016, 16:25
The head change tool on these drives is the least of your issues.
PostPosted: June 7th, 2016, 11:43
Can you paste terminal output?
HddSurgery - Professional Data Recovery Tools
PostPosted: June 14th, 2016, 7:08
Hello Help Disc,
I Have attached the terminal and images of some case I Have tried and failed. How important is date code in Seagate HDD.
Kindly suggest.
PostPosted: June 14th, 2016, 7:19
Hello Helpdisk.
Case 1
Patient Drive Donor Drive
9VMEFKR5 9VMT5JP0
ST3500418AS ST3500418AS
CC46 CC38
Date 11205 10415
Case 2
Z3T9XHJP Z3T59QW2
ST500DM002 ST500DM002
KC45 KC45
DATE 13207 13105
Is it matching. kindly help
PostPosted: June 14th, 2016, 11:11
Case 1, not a match. The date is 7 months or so off.
Case 2, might work but needs more details such as P/N to be sure. However given that it's a DM series, are you sure you've even properly diagnosed it? There's a lot of these getting misdiagnosed as head failures when it's really other issues at the root of it.
PostPosted: June 15th, 2016, 2:03
Hello Data-Medics
Thanks for your valuable reply. I have diagnosed properly and concluded the head fault,(what other problem could be) How close the date need to match.
Case 2
Patient Donor
Z3T9XHJP Z3T59QW2
KC45 KC45
DATE 13207 13105
1BD142-500 1BD142-302
Kindly suggest
PostPosted: June 15th, 2016, 4:50
Is that corrosion on your hddsurgery tool?
Hello Data-Medics
Case 2
Patient Donor
Z3T9XHJP Z3T59QW2
KC45 KC45
DATE 13207 13105
Kindly suggest
This is a good match.
WD Trusted Partners
PostPosted: June 15th, 2016, 6:22
Hello Northwind.
No Corrosion on the tool .
PostPosted: June 15th, 2016, 6:26
Hello Northwind.
How important to match firmware for seagate Head replacement.
PostPosted: June 15th, 2016, 13:14
You post problem on wrong place, you should be looking at pc3k of general forum.
There is a lot of things in DR then just head change.
Seems you changed them good, but other things other should explain.
I would start from adpatives head map etc etc...but this is whole another part of DR
PostPosted: July 25th, 2016, 10:19
Thanks for all suggestion(Northwind and Data-Medics) finally I am able to do successful with Seagate hard disk head replacement. Very Good Tool thanks HDD Surgery.
PostPosted: August 23rd, 2016, 4:29
hi douglas crowell can you explain what was your problem?
Users browsing this forum: Google [Bot] and 1 guest
