Forum rules
 Post subject: HQ PCB Images
PostPosted: July 5th, 2016, 15:28
Dear Friends,
I uploaded a HQ scanned Images for almost all known PCB`s (both sides)
for my Ref. & research, and here is it on my dummy Google Drive
free for anyone who wanted to use & re-publish it.
Hope it helps you
Thank you
:agree: :beer:
Ref. Link:
https://drive.google.com/folderview?id= ... aring#list
 Post subject: Re: HQ PCB Images
PostPosted: July 5th, 2016, 15:47
Online
Thank you!
But this is not enough.
PCB's with the same number have different configurations.
Not compatible with each other.
PostPosted: July 5th, 2016, 16:00
Thanks, but any chance of posting a ZIP containing the images. Rather inefficient and time-consuming to download individual picture files. I use DownThemAll but it didn't display a meaningful list of JPG files to download en-mass.
PostPosted: July 5th, 2016, 18:44
Likewise, many thanks.
I used WGET to download a list of JPEGs which I extracted from the page source. I edited this list by changing "=s190" to "=s4096". The names of the downloaded files are obscure 54-byte hashes, but it should be possible to autorename them with a script (using the info in the page source).
PostPosted: July 6th, 2016, 17:21
The names of the downloaded files are obscure 54-byte hashes, but it should be possible to autorename them with a script.
Actually, renaming the files is unnecessary. WGET can do that via the "--content-disposition" switch.
    wget -t2 -nc -P\your_dir\Toshiba -iToshURL.txt --no-check-certificate --content-disposition
ToshURL.txt would consist of a list of URLs such as ...
    https://lh3.googleusercontent.com/u4bYin-an2-uxzDDQUyw73X5nV2gpa7tx6JDNSXoB_37_2nk8hjSi4YuQ-f-CoJPBkBUJw=s4096
I would write the scripts for you, but different URLs are generated for each session.
PostPosted: July 6th, 2016, 20:53
Down-them-all works a treat, except that you end up with the 190Px images, all properly named automatically. Haven't figured out how to change that yet.
PostPosted: July 6th, 2016, 21:51
Save the page to your HDD as an HTML file. Edit this file. Change every occurrence of s190 to s4096. Then point Down-them-all at this file rather than the website.
PostPosted: July 6th, 2016, 22:45
Thanks for the suggestion, @fzabkar. I relented and used the Bashforth method to download them. Only took a few minutes. Thanks again, @Einstein9!
PostPosted: July 9th, 2016, 5:58
You all welcome.
all the best.
PostPosted: July 24th, 2016, 11:13
Added few OLD folders - good to know it.
in Addition, the SAS to SATA Converter - Old post.
https://drive.google.com/drive/folders/ ... F9jTjZKODQ
PostPosted: December 22nd, 2016, 9:17
Added New Samsung/Seagate PCB`s to the drive.
PostPosted: October 16th, 2019, 4:05
Added some more PCBs..
WD 800077-003 Locked MCU
Users browsing this forum: No registered users and 6 guests
