August 7th, 2016, 20:25
The RAU and ODH chips have open-drain Power Good outputs. Perhaps these are pulled up to 3.3V at the MCU's input pins? If so, then the MCU would be monitoring the various regulators via their PG outputs, and then possibly generating a single PG output of its own which it then communicates to the Marvell controller.
August 7th, 2016, 20:48
I'm wondering whether two of the enables are buffered by the "CV" chips. If so, then the "A" inputs would come from the MSP430, and the "Y" outputs would go to regulators.
http://www.ti.com/lit/ds/symlink/sn74lvc1g07-ep.pdf
- Attachments
- SN74LVC1G07_CV.gif (5.99 KiB) Viewed 21101 times
August 8th, 2016, 4:15
Seems unlikely if there's direct connectivity between MSP430 pins and EN pins on the regulators. But I'll check when I'm back home.
I'm also working on a deal for a 128GB replacement of the MX100. Pictures from many review sites seem to have matching boards for both models (mine is 256GB).
August 8th, 2016, 12:13
I can either get a MX100 in 128GB or a 'micron c400' 256GB at a reasonably affordable price. Supposedly the micron c400 is
equal to the crucial M4.
August 8th, 2016, 15:59
zzattack wrote:Supposedly the micron c400 is equal to the crucial M4.
AIUI it's a Micron design. Crucial is an OEM.
Analysis of Micron RealSSD C400 SED SSD Firmware Update:
http://www.hddoracle.com/viewtopic.php? ... 617&p=8956The instructions for Crucial's firmware update include a screenshot with a Micron Technology copyright:
https://www.crucial.com/wcsstore/CrucialSAS/firmware/m4/070H/crucial-m4-firmware-update-070h-en.pdf
August 8th, 2016, 16:29
Do you think it's safe to get a C400 and pull the MSP430 off of that?
August 8th, 2016, 16:48
Isn't the C400 a completely different PCB?
August 8th, 2016, 19:55
A bit late but here's proper scans of the board:
http://imgur.com/gallery/uz400
Yes they're different models, but they have quite some similarities, i.e. the RAU chips in the same places: http://images.anandtech.com/doci/7864/DSC_5269.jpg
And the rear: http://images.anandtech.com/doci/7864/D ... 1470344694
MSP430 in the exact same spot. Very similar layout. Worth a shot?Nevermind, that's the M550 and not the M4. I'll stick with a MX100 model.
August 9th, 2016, 14:27
Sourcing a used one is looking harder than I had hoped.
The MX200 PCB seems very very similar though, near 1:1 same layout. I'm thinking of getting one of those and move the MSP430 over temporarily. I'm going to need a replacement either way.
August 9th, 2016, 15:27
I would be very cautious and spend some time taking measurements of the working PCB before swapping the chip. The mysterious 43V6ZI chip is a bit of a worry since it is near the power connector. That said, there is a second identical chip at the rear of the PCB. It looks like it might be an LDO regulator (Vin, Vout, Ground, Enable ?).
I'm also uncomfortable with +12V being impressed upon the +3.3V SATA input. I wonder where those resistors go, and whether any damage was caused. Hopefully these resistors connect to the MSP430 and not some other chip.
Best of luck.
BTW, I wish I had your soldering skill.
August 9th, 2016, 16:19
Right, there's that one also. Do you think that's another candidate for transplantation?
At any rate, I don't think the transplant is very risky. After removing the MSP430 I can see that there's no heat generation on the PCB at all. The entire disk draws less than 100mA from my bench PSU.
My plan after opening the MX200 is:
- verify the RAU chips are enabled during normal operation
- do continuity test to see that the same MSP430 pins go to the LDOs
- if so I'm considering that the green light for the transplant
- transplant MSP430 + the dead MOSFET
- after transplant use the bench top psu to allow a minimal current through everything
- verify that RAU regulators are now enabled
- if not, probably give up and undo the transplant
- otherwise hook up the disk and see if I can dump it
August 9th, 2016, 16:28
I would measure all the voltages on the working board, including those at the 43V6ZI chips. If we knew what this chip does, and where it gets its Vin, then maybe we won't need to touch it.
I would also measure the gate voltage at the MOSFET, and its D-S resistance. I'd confirm that the V1 load resistance is also 50 ohms on the donor. Perhaps if you were to compare all the load resistances, then this would give us some confidence that the NANDs and flash controller were OK.
August 9th, 2016, 16:57
Check:
+12v on the capacitorsa (long series),
+3.3 v on the inductor near ODH,
+1.7 v, +1.2 v, and +1.0 v on the inductors near RAU.
August 10th, 2016, 15:52
The MSP430 is marked "V402". I guess that means it has a different firmware version. I wouldn't trust it.
August 11th, 2016, 15:46
Well, enable pins seemed to match so I performed the transplant. Was pretty confident in the soldering but it didn't work so I opted out of further risking the new 250GB disk. Removed the MSP430 from the dead SSD and placed it back on the new MX200. First try wasn't very good, probably because I didn't perfectly level the pads before soldering and it ended up not being perfectly aligned. I took it off, cleaned the pads, used leaded solder instead and although the result was imho still pretty bad, it didn't look misaligned. Pic attached.
Plugged in the disk and it got recognized, hdtune says all blocks are still fine. So no material gain or loss either for today but at least I've got confidence a replacement isn't too difficult. The search for a proper donor continues..
- Attachments
August 11th, 2016, 16:52
FWIW, I had a look at some of TI's power chips. For example, the TPS65910 is a Power Management Unit (PMU) that integrates several switchmode converters, linear LDO regulators, an Embedded Power Controller (EPC), and an I2C interface for communicating with other MCUs. It would be like integrating the MSP430 (an EPC) and all the regulators into a single chip.
The TPS65910 incorporates several power sequences for different processors, and these are selected via two pins, BOOT0 and BOOT1. The first supply to come up is Vio. After all the supplies are up and running, the chip releases the NRESPWRON signal (active low power-on reset).
Of course this chip is of no use to you in your application, but I thought its datasheet might help to understand how your board works.
http://www.ti.com/lit/ug/swcu065f/swcu065f.pdfhttp://www.ti.com/lit/ds/symlink/tps65910.pdfhttp://www.ti.com/lit/ug/swcu056c/swcu056c.pdf
- Attachments
- TPS65910_boot_select.gif (11.25 KiB) Viewed 20899 times
August 13th, 2016, 9:09
Resistance and voltages on the possibly dead PMOSFET measured the same on the donor board so I went ahead and performed the transplant from a 128GB MX100 donor disk. Success! The disk got recognized and I managed to dump all contents
Thanks so much for your help troubleshooting fzabkar!
August 20th, 2016, 19:01
Just FYI ...
I found the following code in a Micron M500 firmware update:
- Code:
000059A0 0A 0D 00 00 4D 53 50 34 33 30 20 46 69 72 6D 77 ....MSP430 Firmw
000059B0 61 72 65 20 52 65 76 3A 20 25 64 0A 0D 00 00 00 are Rev: %d.....
000059C0 14 02 00 80 20 20 20 20 49 4E 46 4F 3A 20 43 68 ...€ INFO: Ch
000059D0 69 70 20 72 65 76 69 73 69 6F 6E 3A 20 25 53 0A ip revision: %S.
AISI, this would suggest that the MSP430 communicates with the flash controller.
August 20th, 2016, 19:58
Here is the header for the fwb.img file (size 0xC00) in the M500 update:
- Code:
00000000 30 33 34 4D CD 4E 2D F8 54 C2 00 08 00 0A 2A ED 034MÍN-øTÂ....*í
The signature is "M430" which would suggest that it represents the firmware for the MSP430.
The following command executes the update:
dosmcli.exe --bus ALL -U fwa.img --segmented 10 -p M500:S0:MU05 -t None --asic-fw fwb.img --bl fwc.img
The MCU is referred to as an ASIC.
Perhaps an alternative solution would have been to purchase a blank MSP430 and program it with the image from a suitable MX100 firmware update.
