Forum rules
 Post subject: How many knows?
PostPosted: May 17th, 2014, 12:05
Dear Experts,
how many of you guys KNOWS where is the Location option of Enable/Disable of Seagate Terminal Log?
thank you
:idea: :idea:
 Post subject: Re: How many knows?
PostPosted: April 24th, 2016, 3:40
My post was like 2Y back.
And now http://ts.acelaboratory.com/index.php?/ ... -in-prague
"Meet your peers from other countries and be the FIRST to learn about the world's ONLY solution for the Seagate F3 Self-Encrypting Drives!
Reserve your attendance for the most important data recovery event of 2016 here."
I like the parts when it say: 1st & ONLY
PostPosted: April 24th, 2016, 5:51
Humm,
I just tried the Option with one of NEW Drives (Grenada)
and my drive is BSY STATE now And very very slow
I did as it says and finally
Good Luck :shock:
PostPosted: April 24th, 2016, 6:00
And here is Attached my 3 TESTING DONORS - BRAND NEW
ST1000DM003 Z4YALP5Z
ST1000DM003 Z4YALPJB
ST1000DM003 Z4YALPED
I dont think there will be a Match better than this. (Dead one is the Last)
PostPosted: June 7th, 2016, 10:46
Yes, been doing those and others for some time now, our methods are different to Ace though.
<itch>
скратчи
PostPosted: June 7th, 2016, 10:55
Are you guys both saying you had solutions for the terminal locked Seagate drives before Ace released it?
PostPosted: June 8th, 2016, 14:15
Just keeping this thread alive
Are there any solutions To Diagnostic Port Locked on later Seagate drives
(different to the other short read channel techniques on some older ones)
And this thread needs a much better title
PostPosted: June 9th, 2016, 0:13
Jared ,
I Hope They Are Saying Just That
PostPosted: June 19th, 2016, 13:19
Amarbir,
I can confirm we (GDRA) had this solution before Ace. :D
Dobre
Murphy was an optimist
PostPosted: August 19th, 2016, 17:59
yeah, i unlocked my first locked grenada in febr. 2015...
Recently finished my tool to unlock Makara and Lamarr Karnak, perhaps some others with signed firmware. Ace has no idea about them apparently, but they are good at marketing :)
No bitcoin donations :)
PostPosted: August 24th, 2016, 18:08
What about drives with PSID? ;)
PostPosted: August 24th, 2016, 19:49
Incredible but they avoided me so far, at least i did not face the problem.
PostPosted: August 25th, 2016, 13:25
Lamarr and Makara are not made without PSID
If you meant SED drives specifically then there is no difference in terms of Diag commands unlock, comparing to non-SED drives with PSID
PostPosted: August 25th, 2016, 14:47
dobrevjetser wrote:
Amarbir,
Dobre
OK, so now that the solution is commercially available do you mind sharing what your technique was?
PostPosted: August 25th, 2016, 15:19
yes, he would mind sharing that.
PostPosted: August 25th, 2016, 19:42
data-medics wrote:
dobrevjetser wrote:
Amarbir,
Dobre
It is completely different logic than Ace's.
PostPosted: August 26th, 2016, 2:56
May be I'm wrong, but as I understand PSID is using in order to encrypt SA and techno key, so PSID is used to form a request to remote sever in order to get techno.
PostPosted: August 26th, 2016, 4:08
i did not really get engaged how the auth is done exactly in the fw since if it is done properly you won't be able to fake it.
PostPosted: August 26th, 2016, 9:57
SA is not encrypted
PostPosted: August 26th, 2016, 19:22
Thanks for explanation.
Users browsing this forum: sin and 8 guests
