Forum rules
 Post subject: Develop the new software for writing ROM for Seagate F3
PostPosted: November 11th, 2013, 23:32
Hello everybody,
I'm going to create a software for writing Seagate ROM for Seagate F3 drive. But I have a problem: when i modify any data on ROM file, i have to recalculate checksum. I have spent a lot of time for analysis checksum on Seagate F3 but i cannot understand.
Can anyone please help to give me any advices ?
Thank you very much.
Best Regards,
SkypID: hddselftest
Email: hddselftest@gmail.com
 Post subject: Re: Develop the new software for writing ROM for Seagate F3
PostPosted: November 12th, 2013, 3:12
My Advice:
Start where Others Stopped (after gathering ENOUGH info. about what you are PLANNING to do)
there are MANY cheap tools which does the same the question is: What is your point of making this?
In Addition, another TIP/Advice, read more about Seagate ROM and how does it effect the Data/Repair
good luck
PostPosted: November 12th, 2013, 3:20
Hello einstein9,
Thanks for your advice.
I have already determined the location of checksum, the number of word for checksum calculator.
There are some tools of calculator checksum with 96 different methods but it does not match with checksum that PC3000 calculated.
The engineer of ACE has really good skill for analysis :lol:
Best Regards,
SkypID: hddselftest
PostPosted: December 12th, 2013, 17:52
Maybe you located a checksum of a ROM block :wink: :?:
PostPosted: December 19th, 2013, 2:15
Tried a lot of but nothing :( .
Is it a common checksum algorithm ?
Best Regards,
SkypID: hddselftest
PostPosted: November 7th, 2016, 13:47
Hi
Its very hard to calculate check sum
By boot code mode ROM write need calculate check sum after every 512 bytes, then proceed to next byte.
If you found the algorithm, please share with me.
Waqas Ali
PostPosted: November 8th, 2016, 17:48
Looking forware to check out your tool !
PostPosted: November 8th, 2016, 21:00
https://github.com/eurecom-s3/hdd_firmware_tools
https://github.com/eurecom-s3/hdd_firmware_tools/archive/master.zip
http://www.hddoracle.com/download/file.php?id=2731
http://www.hddoracle.com/viewtopic.php?f=109&t=1219&p=7976
"This library implements the CRC16 checksum as used by Seagate hard drive firmware":
https://github.com/eurecom-s3/hdd_firmware_tools/blob/master/scripts/hdd_crc.py
PostPosted: November 11th, 2016, 10:14
Hi
Proper Python Script for Calculate Seagate F3 drive Check sum.
Please note , Firmware check sum calculation and ROM write by boot code mode check sum calculation is different.
For rom write by boot code mode, need to calculate check sum after every 512 byte, then check sum, then next 512 byte, until finish. This CRC calculation Equation i am searching. if any one have it please Share with me.
FW CRC code
# Calculate a CRC the same way the CM/script code & self-test/IO code does
def calcCRC(data,sizein,crc):
for i in range(0,sizein):
c1 = crc & 0x00AA
c2 = c1 ^ ord(data[i])
crc = crc + (c2 & 0x00FF)
return crc
def parseTestResultsNewHeader(data,currentTemp,drive5,drive12,collectParametric):
Parser callback for DBLOG data parsing.
global dblData
if 'dexParserOn' in globals():
global dexHandler
if dexHandler == None:
dexHandler = getDexHandler()
dexHandler(data,currentTemp,drive5,drive12,collectParametric)
dbLogBlockCodes = [ 11000, 11002]
dblDelim = ','
tableNameOff = 0
colOff = 1
colWidthOff = 2
tableTypeOff = 5
tableInfoBlock = {
'codes':[11000],
'format':"H"
tableDataRowBlock = {
'codes':[9002,10002, 11002],
'format':"HH"
try:
from dex.tabledictionary import tableHeaders
except:
print "Unable to find tabledictionary for translation in paths %s" % (sys.path,)
DBlogParserOff()
return
# Cut off the one byte results key
resultsSector = data[1:]
# Assume this is a new 5 byte firmware header
# Every firmware header has 2 bytes test number, 2 bytes error code and 1 byte block type
firmareHeaderFormat = ">hHb"
firmareHeaderSize = struct.calcsize(firmareHeaderFormat)
# Validate the size
if len(resultsSector) < firmareHeaderSize:
print "Invalid firmware header. received: %s bytes, expected: >= %s bytes." % (len(resultsSector),firmareHeaderSize)
return
testNumber, errorCode, blockType = struct.unpack(firmareHeaderFormat,resultsSector[:firmareHeaderSize])
# Is this a new style firmware header?
if blockType in (1,):
# On a new style record, the firmware CRC is the last 2 bytes of the firmware record
crcFormat = ">H"
crcSize = struct.calcsize(crcFormat)
firmwareCRCCheck = struct.unpack(crcFormat,resultsSector[len(resultsSector)-crcSize:])[0]
# Calculate the firmware CRC
# First two bytes (test num) and last two bytes (firmware CRC) are not included in the CRC calculation
rec = resultsSector[2:-crcSize]
# Pass the same arbitrary seed value (604 == throwing missiles) as firmware & tester do to ensure a CRC of 0's does not equal 0
crc = calcCRC(rec,len(rec),604)
# Our function returns a 32 bit value, but firmware function returns a 16 bit value so mask it to get a 16 bit value
crc = crc & 0xFFFF
# There is a slim chance an old header would be in this loop by mistake. Compare our calculated CRC with the firmware calculated CRC
# If the CRC check fails, try to process the old style header
if firmwareCRCCheck != crc:
# Initialize index of binary data stream to 25 jump over the command portion of the results.
# For all binary results, the first 25 bytes are made up of a single byte block code,
# Two bytes containing the test number, Two bytes containing the Error code,
# and Two bytes for each of the Ten Parameters, totaling 25 bytes.
data = data[25:]
# New style 5 byte firmware record
else:
# From the data set, remove the firmware header from the beginning and the firmware CRC check at the end
data = resultsSector[firmareHeaderSize:-crcSize]
# Old style 24 byte firmware header
else: data = data[25:]
length = len(data) # Obtains Length of binary data stream
index = 0
while index < (length-4):
format = "HH"
Block_Size,Block_Value = struct.unpack(format,data[index:index+struct.calcsize(format)])
if DEBUG > 0:
print("Block_Value: %s" % str(Block_Value))
if Block_Value not in dbLogBlockCodes:
if Block_Size == 0:
Block_Size = 1 #Prevent the case of bad block header causing an infinite loop
else:
if Block_Value in tableInfoBlock['codes'] or Block_Value in tableDataRowBlock['codes']:
if Block_Value in tableInfoBlock['codes']:
formatA = tableInfoBlock['format'] # Establishes the format for the Struct module to unpack the data in.
tableCode, = struct.unpack(formatA,data[index+4:index+4+struct.calcsize(formatA)]) # unpaks the revision Type from the data list
DriveVars['tableCode'] = tableCode
binDataStartLoc = index+struct.calcsize(format)+struct.calcsize(formatA)
else:
tableCode = DriveVars['tableCode']
binDataStartLoc = index + struct.calcsize(format)
binData = data[binDataStartLoc:index+Block_Size]
if DEBUG >1:
print("Table Info: tableCode=%s" % str(tableCode))
print("row data: %s" % (binData,))
try:
tableName = tableHeaders[tableCode][tableNameOff]
abort = 0
except KeyError:
tableName = ''
print("DBLOG Block code %s not defined in tabledictionary.py" % str(tableCode))
abort = 1
if not abort:
rowData = binData.split(dblDelim)
tableColumns = tableHeaders[tableCode][colOff].split(dblDelim)
if len(rowData) > len(tableColumns):
#expand tableColumns with dummy cols so user has some access to data.
dummyCols = ['dummyCol%s' % (i,) for i in range(len(tableColumns),len(rowData))]
tableColumns.extend(dummyCols)
#expand with nuls if more cols than row output
rowData.extend(range(len(rowData),len(tableColumns)))
## Old Data Format
## dblData['P010_FORCE_CONSTANT'] = [
## {'ITER': '255', 'ZTAB': '9598', 'BDRAG': '0', 'FORCE_CONSTANT': '0', 'POINT': '0'},
## {'ITER': '255', 'ZTAB': '7638', 'BDRAG': '0', 'FORCE_CONSTANT': '0', 'POINT': '1'},
## {'ITER': '0', 'ZTAB': '5878', 'BDRAG': '0', 'FORCE_CONSTANT': '0', 'POINT': '2'},
## {'ITER': '0', 'ZTAB': '4503', 'BDRAG': '0', 'FORCE_CONSTANT': '0', 'POINT': '3'},
#dblData.setdefault(tableName,[]).append(dict(zip(tableColumns,rowData)))
## New Data Format
## dblData['P010_FORCE_CONSTANT'] = {
## 'ITER' : ['255', '255', '0', '0'],
## 'ZTAB' : ['9598', '7638', '5878', '4503'],
## 'BDRAG': ['0', '0', '0', '0'],
## 'FORCE_CONSTANT': ['0', '0', '0', '0'],
## 'POINT' : ['0', '1', '2', '3']
dblData.setdefault(tableName,{})
for key,val in map(None,tableColumns,rowData):
dblData[tableName].setdefault(key, []).append(val)
# Block Size, So index will now reference the start of the next data block.
index = index+Block_Size
PostPosted: February 23rd, 2018, 14:34
i know post is old
but i would like to say included winfof Script is not code for recalc 512 Block in Seagate
Algorithm is totally different and Block is not only 512 + CRC
there are other bytes added to Block
if you still need the Algorithm Let Me know
http://www.hpwlab.com
PostPosted: February 23rd, 2018, 15:04
hpw333 wrote:
i know post is old
i check it use Character not Byte like others , code is correct
but if you Follow winfof it use Byte sending with different alghorithm
other tools use above code by sending block as array of character with FOF aalghorithm
PostPosted: March 4th, 2018, 11:25
alghorithm you attach is useless and not what seagate use in Read or write Rom Process
PostPosted: March 21st, 2018, 17:46
Banned User
Then what is the real crc can you post here
Users browsing this forum: No registered users and 6 guests
