 Post subject: DataCompass size
PostPosted: December 5th, 2016, 16:21
Hello gurus,
i'm doing some experiments with datacompass tool and i'm stuck on a strange issue.
I knew that the size limit of datacompass is 2TB but if i connect any drives bigger than 500gb i can see only a drive recognized as 465GB also from windows administration tools, it seems a driver limitation.
Any ideas?
 Post subject: Re: DataCompass size
PostPosted: December 5th, 2016, 21:24
500 GB = 465.66 GiB
https://www.google.com/search?q=convert+500GB+to+GiB
PostPosted: December 6th, 2016, 15:12
Exactly as stated by @jermy .
On HRT-DRE an 500 GB WD Green will look like this :
This is NOT a tool limitation. The tools are just displaying the capacity in GiB instead of GB.
PostPosted: December 6th, 2016, 16:31
Correct me if I'm misreading, but didn't he say "bigger than 500gb" ?
PostPosted: December 6th, 2016, 16:41
That's how I read it, but then it doesn't make any sense. If there were some kind of capacity limit, one would expect that it would fall on a binary boundary, eg 512GiB, 1TiB, etc.
PostPosted: December 6th, 2016, 16:44
Ups.... Sorry my bad.
You might be correct.
What i still don't understand is this :
livetheenergy wrote:
(...)also from windows administration tools (...)
Is this some sort of option inside Data Compass or is this related to mounting the drive using data compass ? Because if it's related to plug the drive to windows OS and only see that size even on 1 or 2 TB drives then it's not normal at all.
PostPosted: December 6th, 2016, 16:50
Unless the Data Compass doesn't work with drives bigger then 500 GB, hits that limit and display that value no matter how big the drive is ...
PostPosted: December 10th, 2016, 17:46
Hello !
I dont think so.
This one is a 3 TB @ DC.
Regards.
PostPosted: December 10th, 2016, 17:51
That is a NTFS PARTITION that DC is showing. I think DC will not know about GPT... You might still be able to image/clone the drive.
PostPosted: December 12th, 2016, 8:45
Hi guys, i was away, there are some quirks with the datacompass tool. I've tried more drives with DC, these are 1TB or 2TB but DC sees only the first 465 (or 500GB).
If i use a standard usb bridge i can mount the drive correctly and i can see the partition correctly, with DC i cannot see more than 500GB and i don't see the partition.
I'm trying to figure out why this happen.
PostPosted: December 12th, 2016, 8:51
I think it could be something linked with the DC drivers, because i see 465 size limitation also from my storage settings from administration tools (without using DC-PANEL or DC-EXPLORER).
PostPosted: December 12th, 2016, 9:00
Anyway, DC automatically mount any readable drive on windows (it's writtable also if i select the read only option :shock: :shock: :lol: weird!)
PostPosted: December 12th, 2016, 15:32
Do you have the latest version of the software and drivers ?
Try other versions ?
Does anyone have DC and the same problem ?
Try on another computer as well ?
PostPosted: December 13th, 2016, 16:05
Hi, I've tried on two windows xp machine with these versions 8.0 8.22 9.6 9.8 9.96 10, if i remember well with windows 7 shadowdisk doesn't work.
Anyway i want to try to update the driver but i don't find where is the DC driver folder.
it's a shame, I've tried to do some experiments with SD tools but i found strange issues from the beginning.
PostPosted: December 13th, 2016, 18:06
I've DC, But it Works fine upto 2TB HDD.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: December 21st, 2016, 5:02
Online
I test also on 2TB drive and it Works OK with version 10
press total LBA button and check if it show corresct LBA
PostPosted: June 2nd, 2017, 6:00
I've been away for a few months and I have noticed your reply just today. I didn't remember if the total lba were correct, I will try again and i'll tell you!
So this topic could be useful to anyone else dealing with the same bug.
Users browsing this forum: No registered users and 0 guests
