Forum rules
 Post subject: Seagate F3 ROM Boot Loader :
PostPosted: November 27th, 2013, 21:22
Does anyone know how to manually Read/Write ROM from the Yeti Boot ROM ?
Does anyone know interesting commands that can be used on the ROM Boot Loader ?
I did manage to figure out a way to start the ROM Boot Loader but i'm not sure how to play with it :)
Trying the BOOT commands at random doesn't sound like a good idea :)
 Post subject: Re: Seagate F3 ROM Boot Loader :
PostPosted: November 27th, 2013, 21:36
No Pain, No Gain :-)
PostPosted: November 27th, 2013, 22:05
Guess you are correct !
This is a very usefull menu :)
This is how you start the ROM boot mode :
http://malthus.zapto.org/viewtopic.php?f=6&t=689
PostPosted: November 27th, 2013, 23:11
BR sounds like it might be safe to play with. I expect that it would set the baud rate divisor for the UART.
Try "BR" or "BR ?" or "?BR" or "BR 0" (zero).
The last one should produce an error and hopefully a list of permissible baud rates.
PostPosted: November 28th, 2013, 5:14
DS asks for a file name, so it must be related to data transfer (XMODEM / YMODEM / ZMODEM ???)
RD reads memory addresses.
GO probably begins executing at the specified address.
TE might execute a particular test number ???
PostPosted: November 28th, 2013, 7:09
Boot Cmds:
DS Send File
AP <addr> Position Adress for Read/Write
WT <data> Write Byte (autoincrement address)
RD Read Byte (autoincrement address)
GO Go Addr
TE Echo Off/On
BR <divisor> BaudRate
BT Booting from serial FLASH code
WW Write Word
? Help
RET
PostPosted: November 28th, 2013, 19:08
PostPosted: February 2nd, 2014, 16:28
very good article
thank you
http://www.hpwlab.com
PostPosted: July 23rd, 2016, 18:00
What to do after HDD is boot mode?
How write ROM in boot mode?
PostPosted: July 28th, 2016, 15:21
you must have special code for writing ROM, code must be loaded into RAM and executed
PCR extracting. Remote data recovery from DVR. Skype: yustik74
PostPosted: December 15th, 2016, 9:37
I am not able to access the link http://malthus.zapto.org/viewtopic.php?f=6&t=689.
I did see the cached page but its missing the details of getting the boot ROM.
Could someone please help me with getting boot rom on barracuda 7200.12
I dont have access to the PC-3000 utility.
PostPosted: December 15th, 2016, 17:16
jkl0l wrote:
Could someone please help me with getting boot rom on barracuda 7200.12?
Read file 32A:
http://www.hddoracle.com/viewtopic.php?f=83&t=1455
PostPosted: December 19th, 2016, 15:36
Thanks @fzabkar for replying.
I tried downloading but I am getting 0x25 error code.
When i reboot the hdd, it doesnt show me the bootrom message. Could you please explain me how to get bootrom shell?
PostPosted: December 19th, 2016, 20:23
Instead of malthus.zapto.org use hddoracle.com :
http://hddoracle.com/viewtopic.php?f=6&t=689
