 Post subject: Installing Insight under win 10
PostPosted: February 2nd, 2017, 17:27
I'm trying to install Insight 4.4 on a fresh windows 10 and it keeps trying to install .net 4.6.1 and it fails, win10 has a newer version already install and I can't past that step to install the sql,hasp and insight. how can I bypass it?
 Post subject: Re: Installing Insight under win 10
PostPosted: February 6th, 2017, 4:53
The easiest way is just to install Insigh 4.5 or higher versions instead. However, if your subscription does not allow using fresher software versions, here is the workaround.
The thing is that Microsoft rolled out .NET Framework 4.6.1 several weeks later after our 4.4 release. Atola Insight 4.4 is based on .NET 4.6 Framework (not 4.6.1) and its framework version check during installation implemented was made according to the rules by Microsoft. For some reason they decided to change the rules with the Windows Update and now we have what we have.
To cope with the issue, please follow the scenario:
1. Open HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Client in Registry Editor
2. Save 'Release' key value to some file
3. Change 'Release' key value to 393297 in Decimal base (mode)
4. Install Atola Insight Forensic 4.4 and run it
5. Change 'Release' key value back using the saved value at point 2
If you face permission restrictions while changing registry keys, please follow the tips explained in Steps 1-6 here:
http://www.groovypost.com/howto/take-fu ... stry-keys/
Vitaliy Mokosiy
CTO, Atola Technology
PostPosted: February 6th, 2017, 11:57
Thank you for the answer Vitaliy, I made the changes but still have the same issues.
PostPosted: February 6th, 2017, 12:25
I don't have ATOLA but if the goal is to "trick" the software intro thinking that you have another version of .NET Framework you can as well check if you have the same branch of NET Framework Setup registry keys under the HKEY_CURRENT_USER and edit those as well ...
Also ... on your screen shots you can try to edit the v4.0 entries as well the same way you have done with v4 ...
PostPosted: February 6th, 2017, 12:37
Mine looks like this :
Instead of creating a new Release key value try to change the Version to something like 4.6.0 ...
Maybe this will work ...
Remember the idea is to "fool" the software intro thinking that you have a diferent version of Framework, so use your imagination !!!
PostPosted: February 6th, 2017, 12:47
Wait ...
Release value 393297 should be DECIMAL and NOT HEX
On your picture you have set the value as HEX (0x) and not as DECIMAL.
Just try again.
Edit the Release key and set 393297 value but select the DECIMAL value for the DWORD when editing it with regedit.
PostPosted: February 6th, 2017, 14:26
Thank you Spildit for pointing my mistake :oops: I got it installed , thank again
Thank you it worked !!
PostPosted: February 6th, 2017, 14:34
Coooolll !!!
Glad it worked !!!
Users browsing this forum: No registered users and 0 guests
