February 8th, 2017, 9:16
How to check store bits in harddisk is there any software install in it?
February 8th, 2017, 13:35
If I'm reading correctly, I think he's concerned about bit degradation and looking for software to check for that.
@RITESH - Just backup all important data onto a second device. All HDDs fail eventually, if not from degradation they will die from failed read/write heads. Then monitor the drive's S.M.A.R.T. to see if it's developing pending or re-allocated sectors. This will tell you if it's degrading.
February 9th, 2017, 1:29
hello,
i want to learn as we do in microcontroller we check all hex code in it...
February 9th, 2017, 1:45
ok i have run winhex
here it is how to run
- Attachments
February 9th, 2017, 3:26
hello,
how to check inside ram data??
February 9th, 2017, 9:20
WHAT YOU SAY RAM DATA / ROM DATA WHAT IS THE PROBLEM IN HARD DISK
https://www.facebook.com/Galaxy-Data-Re ... 230196828/
February 9th, 2017, 10:54
hello,
i want to understand it how it work the sata store how to read it is showing all c d e drives.
February 10th, 2017, 2:11
YOU WANT TO RECOVER DAMAGE DATA ????
February 10th, 2017, 3:11
hello
how data is damaged and how to recover it??
February 10th, 2017, 3:25
This is a joke, right?
February 10th, 2017, 5:00
no, i have no idea how data is lost may be deleted?
please tell how to recover it and why hardisk has so many cylinder.
February 10th, 2017, 5:02
ok i found from your website that it may be:
Deleted files
formatted drives
dead drives
clicking hard drives
dead drives
unreadable cd/dvd
how to learn it?
February 10th, 2017, 9:58
how to work with it?
February 10th, 2017, 11:39
Perhaps you could find someone more fluent in English to more clearly explain the situation and what you're trying to accomplish so we can actually understand you. What we are getting right now it the equivalent of:
I SICK
NEED KNOW HOW HEALTHY AGAIN
TELL ME!!!
February 10th, 2017, 14:31
data-medics wrote:I SICK
TELL ME!!!
This is a terrible english translation, you've made the point.
Here, an example of equivalent terrible italian.
IO MALE
DEVE SAPERE COME SANO ANCORA
DIMMI!!!
February 11th, 2017, 1:23
ok, sir how to learn it?
February 11th, 2017, 7:35
Look, you need someone who will teach you physically. Here You will find everything is going on over the head
February 16th, 2017, 4:19
hello,
how logic board work with hardisk??
February 17th, 2017, 5:25
hello,
which motor and controller bridges is used to run
it does it rpm changes or constant fixed?
February 19th, 2017, 0:03
Hi Ritesh ,
You cannot ask so many questions in one thread ,You are trying to learn 100's of things in fraction of seconds no one can learn like this .If you want data recovery training you are welcome to chandigarh .We charge RS :75000/- For Approx One Month Training For Data Recovery With Room Rent And Food .We have 2 Classrooms One For HDD Recovery and One For NAND .NAND We Do Not Teach Yet But Will .We Are Also Planning to Hire a NAND Training Tutor As We Are Into Starting Stage In NAND Flash Work .
