February 18th, 2017, 3:42
Hello
i have HDD Samsung 1,8" 200GB HS20YJZ USB 2.0... And its starts, mounting but nothing else... null data area access.
I looking for PCB PATA compatubilyty becacuse chip USB bridge dont have sata interface
someone have similar case?
Best regards
February 18th, 2017, 13:56
February 18th, 2017, 18:47
Check the diagnostic output from the serial terminal pads.
- Attachments
- serial_Tx_Rx.jpg (13.54 KiB) Viewed 17529 times
February 19th, 2017, 4:52
U4792:2800
HEAD00:FIND
HEAD01:FIND
HEAD02:FIND
HEAD03:FIND
Start Loadconfig
SRVTBL:OK
[SAIL:02 0041:0041:0040 0100:0104]
R:00 18_000000.0.0058 0001
ENG>
retract C:0000056030 H:+00003
February 19th, 2017, 4:55
Disk is recognized via USB in PC3k but i cant backup any resources and in task image copy cant not running.
February 19th, 2017, 9:01
This ^ is the full terminal log ?
February 19th, 2017, 14:52
Yes, this is only it... every time when on hdd
February 19th, 2017, 21:45
You might don't have a choice but to solder a PATA connector to it
October 8th, 2020, 19:08
Krio_Man, did you solve the issue? If so, how?
I'm stuck with such a drive and need to save the data.
The disk did spin up a week ago, but now it is over.
When plugin it in PC, the light goes on for a second and then nothing.
No indication of mounting in OS either.
Getting another PCB for this HDD is all that I can think of.
July 24th, 2021, 12:16
rbgo wrote:Krio_Man, did you solve the issue? If so, how?
If you still need a new PCB, i have one, my HDD has the click of death but the PCB still works fine.
