rogfanther wrote:
Supposing the person doing the recovery has the necessary knowledge, it would not be necessary to open the enclosure and connect the disk directly if the only problem was a quick format.
The loss of some files and folders could be considered normal, due to things writing to the drive after it being formatted.
thank you for your time and your response.
the thing is when i noticed that i formatted the wrong drive, i just immediately disconnected the drive and put it aside to deliver to a recovery center.
i never wrote anything on it...
now, what do you think... does it have a different and a better result if i do the second recovery with opened shell and connect the hdd directly to the board?
