Forum rules
 Post subject: Read and Write F3 Arch Sys files with HyperTerminal :
PostPosted: December 28th, 2015, 18:40
This should be added to the Knowledge base :
On this guide I'm going to show how to read and write Seagate F3 Arch Sys Files (Firmware Modules) by using HyperTerminal and a TTL adaptor only ! No need to acquire expensive firmware tools !
Please do note that this procedure works with some F3 Arch drives but it will not work on all of them. Only some models support the r and w commands.
The following guide might be of use in cases where some sys files needs to be replaced and the user doesn't have access to expensive firmware tools.
http://www.hddoracle.com/viewtopic.php?f=83&t=1455
Regards.
 Post subject: Re: Read and Write F3 Arch Sys files with HyperTerminal :
PostPosted: March 3rd, 2017, 4:43
seagate vsc for send ctrl data like sct cmd: 0x0000 0x0001 0x00BE 0x2459 0x0000 0xa0 0x3F
seagate vsc for Read data like sct cmd: 0x0000 0x0001 0x00BF 0x2459 0x0000 0xa0 0x2F
Data and Disk security laboratoryhttp://www.dadslab.net
Skype: peter.zyo
PostPosted: March 12th, 2017, 10:54
Many thanks for sharing those.
Do you have any EXTRA "key" commands to send using the mentioned VSC ?
Thanks.
