Hello.
I have a problem with the disc Seagate ST1000LM024.
Model: ST1000LM024
HDD P/N: HN-M101MBB/LC2
REV.: A
F/W:2BA30001
The drive is connected via cable "USB 3.0 to SATA."
Windows 10 sees the drive in File Explorer is not visible.
However, after analyzing the SeaTools in the Drive Information writes - Security Mode: Locked.
There is also no visible firmware and S / N. Which shows a screen from the program SeaTools.
The programs for the analysis of SMART shows that:
I bought a terminal disk, according to the instructions I connected the drive to the power supply from the computer and USB terminal on the cable.
In the "Terminal" appeared parameters:
ActiveFW : 00FWVer : 0001SATA PLL cal doneDDR size detected = 16MB DDR size detected = 16MB*PAUNI_L2958*PA VID=0011 PN=000D Rev=0001- PA_LSI2958 Found*PAUNI_L2958*PA VID=0011 PN=000D Rev=0001- PA_LSI2958 FoundU
S_0SO_1
SPU@29'C,5000mV
IS=5
CLA ..36/47
HO..OK
HO RPM=838 OK
AC 1241
ST..Skip..OK
mS1 00000003
GT:432
SC(L):4090/42
BE.N:22
LD..OK
SK C: 7963 H:0
Loaded FIT ( 0: 0: 1)
CalibTable Loaded. Rev:0x1B
ResoTable Loaded. Rev:0x01
Bump Limit Loaded. Rev:0x01
RRO1xTable Loaded. Rev:0x01
Fw Active 00
| 115 | MOVLY001 | 1 | 0 | 10 | 1140 |
Ovly loaded to 0x00014D00
Ovly loaded to 0x1002DF20
FdtTable Loaded. Rev:0x02
| 17 | SLIST | 4 | 0 | 0 | 1140 |
| 15 | VLIST | 2 | 0 | 0 | 1140 |
Unknown file id 384
Up MC
PwrOn RRO1x @ H0
Table) cos = 453632, sin = 56064
Coeff) cos = 90209, sin = -1556
DiskSlip : 64 [SrvTrk]
DiskSlip : 76 [SrvTrk]
0. phs diff 1 [wedges] Table) 8, coef) 9
PwrOn RRO1x @ H2
Table) cos = 450560, sin = 60928
Coeff) cos = 37258, sin = -58932
DiskSlip : 68 [SrvTrk]
4. phs diff 8 [wedges] Table) 9, coef) 1
TgtCyl: 832
Hd: 2 Zn: 0 Avg.:- 88
TgtCyl: 266176
Hd: 2 Zn: 1 Avg.: 1025
SVCAL(0080,0000)-->PASS
[DIPM_TMOUT:00000000]
ENG>| 152 | ZONHEAL3 | 63 | 0 | 0 | 1140 |
[INIT_ATWH_V2 REV:0008 GRP:1]
RdyTm = 25697555 us
EPOK
healing Enable 003C 001E 0000 001EmS1 00000003
UF 3 1stGrayErr Hd:0
SK C:185455 H:1
SC(U)..4090/188
UD..OK : 188
PK_4 C: 32 H:1
The instructions write to trigger F3 need to click a few times CTRL + Z, but nothing happens.
Please help
