 Post subject: how to fix hdd samsung f3
PostPosted: April 6th, 2017, 5:52
i have to many bad sector in hdd samsung f3..can you help me how to fix the bad sector ??
 Post subject: Re: how to fix hdd samsung f3
PostPosted: April 6th, 2017, 9:50
Bad sectors can not be fixed
If the data is needed, the best approach would be, hardware imaging
PostPosted: April 6th, 2017, 18:11
And if data is not needed and you have a lot of bad sectors, just discard the hdd.
PostPosted: April 6th, 2017, 18:27
If you want to try salvaging the drive (not your data) ...
Learning to BURN IN Sammys, any hints?
http://www.hddoracle.com/viewtopic.php?f=19&t=1657
PostPosted: April 7th, 2017, 3:14
i have samsung type HD.and many bad sector in there.
how clean the drive from bad sector ??
can you help me ??
PostPosted: April 7th, 2017, 10:20
can you help me ??
You go to computer shop,
You buy a new HDD, if possible either Hitachi or Toshiba,
Then you replace old Samsung with bad sectors with brand new drive.
Done !!!
:D :D :D
If not you can get BURN IN resources for Samsung firmware tool like PC-3000, MRT, SeDiv, SHT, etc and try to run BURN on Samsung but it will NOT repair bad sectors it will just mark them as bad and prevent the drive from using them.
PostPosted: April 12th, 2017, 17:51
HEllo Spildit ... i`m new here... :D
i world to you send me email,,juniocruz02@gmail.com,,i need to active free demo from SHT v4.0.9 Demo or other version you can help me,, my HDs is SMART BAD ....
wait you ... thasnk much ...
PostPosted: April 13th, 2017, 13:11
What ? :shock: :shock: :shock:
1 - Go to shop.
2 - Buy new drive.
3 - Replace old drive with new one.
4 - Done !!!
If you care for your data and "SMART is BAD" then ... backup .... NOW !!!
PostPosted: September 8th, 2017, 9:36
i need mhdd for my drive... ?
PostPosted: September 8th, 2017, 14:55
Is this a joke ?
