Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
 Post subject: Repair Your Seagate HDD
PostPosted: May 18th, 2017, 5:33
Banned User
hi i used this command that repaired my hdds :D :D
m0,2d,1,ffff,ffff,ffff,ffff,22
m0 = user partition
2d = 101101 = enable format seacos, enable reformat zone,enable log,disable certify,enable format, enable corrupt primary defects
ffff = max write retry
ffff = max read retry
ffff = max ecc level
ffff = max rewrite retry
22 = valid key
and then regenrated translator with this command gives good performance :D :D
m0,2b,3,0,0,0,0,22
Mohammad Mazaheri
Email: mazaheri.online@gmail.com
Mobile: +989185005214
 Post subject: Re: Repair Your Seagate HDD
PostPosted: May 18th, 2017, 6:46
That's very good seagate locked diagnostic commands so that suchlike "kind" people will step aside.
PostPosted: May 18th, 2017, 7:46
It might be even more helpful to people to know exactly what model HDDs you ran this on. And what was "wrong" with them to begin with.
sometimes people run the wrong thing on the wrong drives, and when the drive still miraculously works, they lead others astray. You have to be careful.
PostPosted: May 18th, 2017, 8:22
Banned User
This Commands Works On All F3 Series
Mohammad Mazaheri
PostPosted: May 18th, 2017, 11:25
you dont get it...
PostPosted: May 18th, 2017, 14:02
Goes without saying .... the command will ERASE ALL DATA ON THE DRIVE.
PostPosted: May 18th, 2017, 14:05
Original thread - viewtopic.php?f=1&t=35342
PostPosted: May 18th, 2017, 18:10
Thats what I am saying spildit.. people will just run this no matter what seagate or what issue and expect drive to be fixed. There is no context at all in OP.
PostPosted: May 19th, 2017, 3:14
Banned User
i fixing drives i dont want data
i know all data will be erased
in iran people dont have enough money for recovering hdd data
Mohammad Mazaheri
PostPosted: May 22nd, 2017, 15:09
mmzhr, was the computer, that the troubled HD was externally attached to, using either Windows or Linux based program? What program was that? I'd like to learn more!
"Take care of thy backups and thy restores shall take care of thee." Ben Franklin
http://collegecafe.fr.yuku.com/forums/4 ... hnologies/
PostPosted: May 22nd, 2017, 15:29
Those are TERMINAL COMMANDS send to the drive by terminal software like putty, hyperterminal, using TTL adaptor.
PostPosted: May 23rd, 2017, 12:12
mmzhr wrote:
...repaired my hdds:
m0 = user partition
22 = valid key
and then regenerated translator with this command gives good performance :D :D
m0,2b,3,0,0,0,0,22
mmzhr, are there any EZ-read DOCs or TEXTs for us beginners? I'd like to learn more in order to better appreciate what you hardware folks do!
PostPosted: May 25th, 2017, 13:28
Well,
i do not support seagate locking terminal commands .Just see the hell that is broken loose in ST1000LM035 and ST2000LM007 with Signed Firmware and what not
PostPosted: May 25th, 2017, 23:39
Don't you think locking stuff is obvious decision for Seagate? Based on group of silly people who shares in open sources huge amount of terminal commands and even internal documents of its description its quite ok. 99% of newbies type all commands they find without realizing their meaning. Personally I have 1-2 cases a month of customers who "tried themselves to format SA" with commands they found on web in order to recover data! And as I said above its good that typing any suchlike commands on a newer drive (which has PSID) will have no effect.
PostPosted: May 26th, 2017, 2:24
logical yes, but Holdens and Ford argument...
or John Deere argument or whatever binary argument works in your neck of the woods.
one says lock out inexperience for their own safety, other says I paid for it, I want to be able to do whatever I want with it.
IMHO you could find a million threads around the intern to cut and paste onto the bottom of this one..
PostPosted: May 27th, 2017, 6:33
Seagate can not be changed under a guarantee in Russia.
Therefore, whether you like it or not, the discussion will continue.
And new tools and methods will appear :lol:
PostPosted: May 27th, 2017, 10:29
Well,
At Head and Platter Level Already we have tools .But At Firmware Level there is Not Much That Can Be Done .This Time Seagate is One Step Ahead ,Its Not a Piece of Cake To Break The Current Rom/firmware Signed Code Man
PostPosted: May 27th, 2017, 13:12
Well,
Where there's a will there's a way
:D :D :D
PostPosted: May 28th, 2017, 10:27
m0 = user partition
22 = valid key
m0,2b,3,0,0,0,0,22
I have no intention of trying this or any other script; I simply would like to learn a little bit about what each line does -- to better appreciate this process, and when possible, to direct individuals with certain HD problems to DR companies/specialists.
PostPosted: May 28th, 2017, 13:20
RolandJS wrote:
m0 = user partition
22 = valid key
m0,2b,3,0,0,0,0,22
Those are not "scripts". Those are individual commands for Seagate F3 arch drives that you send over TTL/Terminal.
F3 ARCH Commands :
http://www.hddoracle.com/viewtopic.php?f=6&t=3
(those are for 7200.11 and newer)
ST-10 commands (for 7200.10 and older) :
http://www.hddoracle.com/viewtopic.php?f=6&t=2
Grab this PDF :
http://www.hddoracle.com/viewtopic.php?f=6&t=2#p1897
Also read :
http://www.hddoracle.com/viewtopic.php?f=6&t=845
http://www.hddoracle.com/viewtopic.php?f=6&t=1391
Users browsing this forum: Bing [Bot], Exabot [Bot], Google Adsense [Bot], lcoughey and 31 guests
