 Post subject: wd sedlock problem
PostPosted: June 11th, 2017, 11:40
hi guru
is any way to solve sedlock problem
on wd drives without pc3k?
 Post subject: Re: wd sedlock problem
PostPosted: June 11th, 2017, 12:34
Yes.
It's very easy to enable/disable SED to gain SA access.
The problem would be to decrypt the data...
If the drive have some FW issues you might disable SED, fix firmware and re-enable SED. This can be done even on RAM by patching config (module 02).
But if you can't fix the firmware or if you can't gain access to the UA (LBA) with original PCB and SED turned back on then you might have problems as the data would be encrypted ....
PostPosted: June 11th, 2017, 15:56
thanx for your fast reply spildit but mrt can access some module like 01 32 but can't access 02 module to save and patch or edit for sed unlock can you explain how can i do this by mrt.
PostPosted: June 11th, 2017, 15:58
This is strange. Either SA access is locked and you can't access ANY module or SA access is not locked and you can access all modules.
Are you sure the SA is ok ?
PostPosted: June 11th, 2017, 16:02
yes ican access the sa in diagnosis mode but i can't edit 32 because of sed.
if i pass sed and apply slow responding and put sed back i can decrypt the disk by mrt.
PostPosted: June 11th, 2017, 16:43
Ok.
If you read 02 in RAM and if you patch 02 in RAM you can disable SED.
PostPosted: June 11th, 2017, 16:53
thank you spildit i will try.
PostPosted: June 12th, 2017, 1:38
dear spildit
i try read from ram but mrt can't read from ram too.
what if i buy wd marvel utility you think can solve this problem?
PostPosted: June 12th, 2017, 14:30
MRT should be able to do the job ....
Contact tech support ?
You can try with WDMarvel DEMO version. If you can read RAM with it and check config on RAM then most likely you can disable SED. Problem will be decrypt the data.
PostPosted: June 29th, 2017, 2:49
hi spildit the problem solved by pc3k.
and you were right it was not a sedlock drive it was a mrt weakness.after the drive com ready when click auto the drive goes to busy and mrt can't handle this situation but with pc3k it was very simple.
PostPosted: June 29th, 2017, 15:44
MRT tool for WD is ... Junk.
You should try WDMarvel one day. It's really good. And of course SeDiv is very powerfull as well.
Users browsing this forum: No registered users and 0 guests
