 Post subject: wd sedlock problem
PostPosted: June 11th, 2017, 11:40
hi guru
is any way to solve sedlock problem
on wd drives without pc3k?
 Post subject: Re: wd sedlock problem
PostPosted: June 11th, 2017, 12:34
Yes.
It's very easy to enable/disable SED to gain SA access.
The problem would be to decrypt the data...
If the drive have some FW issues you might disable SED, fix firmware and re-enable SED. This can be done even on RAM by patching config (module 02).
But if you can't fix the firmware or if you can't gain access to the UA (LBA) with original PCB and SED turned back on then you might have problems as the data would be encrypted ....
PostPosted: June 11th, 2017, 15:56
thanx for your fast reply spildit but mrt can access some module like 01 32 but can't access 02 module to save and patch or edit for sed unlock can you explain how can i do this by mrt.
PostPosted: June 11th, 2017, 15:58
This is strange. Either SA access is locked and you can't access ANY module or SA access is not locked and you can access all modules.
Are you sure the SA is ok ?
PostPosted: June 11th, 2017, 16:02
yes ican access the sa in diagnosis mode but i can't edit 32 because of sed.
if i pass sed and apply slow responding and put sed back i can decrypt the disk by mrt.
PostPosted: June 11th, 2017, 16:43
Ok.
If you read 02 in RAM and if you patch 02 in RAM you can disable SED.
PostPosted: June 11th, 2017, 16:53
thank you spildit i will try.
PostPosted: June 12th, 2017, 1:38
dear spildit
i try read from ram but mrt can't read from ram too.
what if i buy wd marvel utility you think can solve this problem?
PostPosted: June 12th, 2017, 14:30
MRT should be able to do the job ....
Contact tech support ?
You can try with WDMarvel DEMO version. If you can read RAM with it and check config on RAM then most likely you can disable SED. Problem will be decrypt the data.
PostPosted: June 29th, 2017, 2:49
hi spildit the problem solved by pc3k.
and you were right it was not a sedlock drive it was a mrt weakness.after the drive com ready when click auto the drive goes to busy and mrt can't handle this situation but with pc3k it was very simple.
PostPosted: June 29th, 2017, 15:44
MRT tool for WD is ... Junk.
You should try WDMarvel one day. It's really good. And of course SeDiv is very powerfull as well.
PostPosted: November 22nd, 2018, 14:23
Spildit wrote:
Yes.
could you tell me how ?
PostPosted: November 22nd, 2018, 16:03
siamak5561 wrote:
Spildit wrote:
Yes.
Ok.
And the drive full model is ?
Did you try to gain SA access ? Can you read/write module 02 ? Do you have access to modules ?
PostPosted: November 22nd, 2018, 17:44
Spildit wrote:
siamak5561 wrote:
Spildit wrote:
Yes.
Ok.
I ask this question generally, is there any straight method to disable sed or its different from drive to drive?
what is mean of patching mod 02 ?
PostPosted: November 22nd, 2018, 18:02
Does this help ?
http://www.hddoracle.com/viewtopic.php?f=3&t=1974
PostPosted: November 22nd, 2018, 18:03
SED locked/unlocked module 02 :
http://www.hddoracle.com/viewtopic.php?f=59&t=821#p9077
PostPosted: November 23rd, 2018, 16:37
yes you can do it by mrt know but first you have to short tv9 and tv10 point in pcb or use a visit card and then when you get the id go in kernel mode and from the rom menu disable mod 411 and turn of/on the harddisk.
after this you can access the sa in all mode you can solve slow responding and edit mode32 and change 01 to 00 in mode 02(the location its different in families)but when you read the post mentioned above you can find out the location.
and after edit don't forget enable (sed and mod411) you need the sed for decryption.
good luck
PostPosted: November 24th, 2018, 12:17
hi
after solved SED the hdd have week head how i can imeage by selactive head ?
PostPosted: November 24th, 2018, 12:26
Create a DE task, do a headmap and disable the weak head.
http://www.facebook.com/PCLAB.Assistencia.Tecnica
ACELab partner
PostPosted: November 24th, 2018, 13:39
Spildit wrote:
Hi I read that tread but I didint know which byte I need to change from 01 to 00
is there any easy method to recognize that in all of hard drives ?
here is my mod 02
02.zip [1.23 KiB]
Downloaded 12 times
Users browsing this forum: No registered users and 0 guests
