Post new topic Reply to topic  [ 51 posts ]  Go to page 1, 2, 3  Next
 Post subject: WD5000BMVW-11S5XS0
PostPosted: June 29th, 2017, 11:32
Hello!
I have received the drive in topic (WD5000BMVW-11S5XS0 - FireBird - 2060-771801-002) with completely fried ROM and 2 missing legs. :)
I have connected ROM IC to programmer but unfortunately, all I get in hex is (FF).
I have tried several ROM's and LDR's but no luck. No access to SA to determine the correct version of original ROM.
Any suggestions would be highly appreciated.
Thanks in advance.
 Post subject: Re: WD5000BMVW-11S5XS0
PostPosted: June 29th, 2017, 13:58
unknown wrote:
Hello!
Thanks in advance.
Firebird have unique data in ROM in module 4F, so you'll need the original ROM.
Maybe someone can access the damaged ROM. I very much doubt it's "fried", more like someone tried to switch it to another PCB and broke it :-(
I suggest you contact Allan in Denmark - user "digisupport"
PostPosted: June 29th, 2017, 14:11
Yes that's what happened as the customer told me :(
Thanks for reply Mr. Sean.
PostPosted: June 29th, 2017, 16:55
Here's the drive front label.
PostPosted: July 1st, 2017, 4:39
Better to contact user Spildit, it is not a problem for him at all.
PostPosted: July 1st, 2017, 14:50
It is a problem.
Firebird have unique data in ROM in module 4F as stated.
Also if you have external ROM then there are no copy of ROM modules and 4F on platter.
You may want to try "hot swap" but most likely it will not work as well ...
Maybe you should try some more combinations of ROM/Module 11 and pray ?
PostPosted: July 1st, 2017, 15:05
Spildit wrote:
It is a problem.
Thanks for the reply. :)
I am keeping try several ROM's and LDR's. :)
PostPosted: July 2nd, 2017, 2:55
Post a picture of your damaged rom chip. Many "slaughtered" chips can still be accessed.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: July 2nd, 2017, 9:09
The guy applied too much heat already
PostPosted: July 2nd, 2017, 12:46
Wow, too much heat indeed!
PostPosted: July 2nd, 2017, 13:00
And that kids, is why you never use a flamethrower to remove a ROM chip :lol:
This is exactly what's wrong with people doing DIY recovery.
PostPosted: July 2nd, 2017, 14:38
I told you :)
I don't know if the customer did it by himself or someone else really did it. :)
PostPosted: July 2nd, 2017, 14:50
Did you try hot swap ?
Any luck ?
PostPosted: July 2nd, 2017, 15:01
unknown wrote:
I told you :)
There is another way to get info. Does not always work but is possible
<itch>
скратчи
PostPosted: July 2nd, 2017, 15:11
Any luck ?
Unfortunately, I don't have a matched donor
PostPosted: July 2nd, 2017, 15:12
scratchy wrote:
unknown wrote:
I told you :)
Can you please share it?
PostPosted: July 2nd, 2017, 20:51
Could you upload your collection of ROMs or 4F modules? I'm curious as to how they differ from other families.
PostPosted: July 3rd, 2017, 3:38
Auch, reading out that one is not an option any more.
PostPosted: July 3rd, 2017, 4:20
List here the ROM ver.`s you tried and did not work
to avoid sending the same files back
PostPosted: July 3rd, 2017, 7:33
Thanks for trying to help my friend. :)
Here we go:
00030078
00030080
00030052
00030038
00030044
0003004A
0003001U
0003003V
0003006G
With matched loader for every LDR. (with/without SA Blocked)
Unfortunately. :( ( all I get for every time trying to read anything is FF)
Thanks for trying to help Mr. Frank.
Users browsing this forum: Google [Bot] and 17 guests
