Forum rules
 Post subject: SMART Error Log 07 - how to read it ?
PostPosted: July 18th, 2017, 4:43
Hi guru's ,
could you tell me how to read Self-Test EXT Error Log ?
B0 command doesn't work.
 Post subject: Re: SMART Error Log 07 - how to read it ?
PostPosted: July 18th, 2017, 4:49
Drive's vendor, model, family?
PostPosted: July 18th, 2017, 10:44
Is it a VSC ? :shock:
HGST HDS722020ALA330
PostPosted: July 18th, 2017, 16:19
Deskstar 7K2000 and Ultrastar A7K2000 Specification v1.0:
https://www.hgst.com/sites/default/files/resources/USA7K2000_DS7K2000_OEMSpec_r1.4.pdf
The SMART Read Log Sector (Subcommand D5h) is documented on page 207.
Note: Log addresses 03h and 07h are used by the Read Log Ext and Write Log Ext commands. If these log addresses are used with the SMART Read Log Sector command, the device shall return command aborted.
The Read Log Ext (2Fh) command is documented on page 144.
PostPosted: July 19th, 2017, 4:14
Yes, but very obscured... :(
I don't get it. Do you?
PostPosted: July 19th, 2017, 4:47
2Fh is a 48-bit command.
    FR = xxxxh (log specific, reserved by ATA standard, maybe set to 0000 ???)
    SC = nnnnh (number of sectors to be read from log)
    SN = 07h
    CL = ssssh (first sector/page of log to be read, 0000 is first sector)
    CH = don't care
    DH = A0h or B0h (master/slave)
    CR = 2Fh
PostPosted: July 19th, 2017, 7:58
Maybe "brute force" is needed?
PostPosted: July 19th, 2017, 16:43
Read the ATA standard. If that doesn't help, then you could examine the relevant code in the open source smartmontools project.
Otherwise you could try the following MHDD script (untested).
; read first sector of Self-Test EXT Error Log 07h
; cycle through values of 0000 - 0x00FF for Features Register
reset
waitnbsy
; get first page
%fr = -1
@loop:
%fr = %fr + 1
if %fr = 256 @end
waitnbsy
regs = $00 $00 $00 $00
waitnbsy
regs = %fr $01 $07 $00 $00 $a0 $2f
waitnbsy
%error = iserror
if %error = 1 @loop
checkdrq
sectorsto = logpages\%fr.bin
goto @loop
@end:
PostPosted: July 19th, 2017, 16:55
Maybe your drive doesn't support the Self-Test EXT Error Log ?
PostPosted: July 19th, 2017, 16:57
Oh ....
As shown on my HRT screen capture this is exactly correct !!!
PostPosted: July 19th, 2017, 17:02
reset
waitnbsy
; get first page
%fr = -1
@loop:
%fr = %fr + 1
if %fr = 256 @end
waitnbsy
waitnbsy
waitnbsy
%error = iserror
if %error = 1 @loop
checkdrq
goto @loop
@end:
It looks like it should work ....
I've tested this on my drive :
And got this :
It didn't ABORT as it did when using the read S.M.A.R.T. command.
PostPosted: July 19th, 2017, 17:08
It doesn't matter what i place on the error/feature register. I did test with 00, 07, 10, etc and whatever i place there it doesn't matter i allways get the same data/log on the buffer.
