 Post subject: maxtor diamond 10 - 250 gb ata 133
PostPosted: July 16th, 2017, 14:58
maxtor diamond 10 250 gb ata 133 (ide)
i need rx, tx, gnd pin connections can cany one help on this?
is my old device his work well i need recovery any files over them.
 Post subject: Re: maxtor diamond 10 - 250 gb ata 133
PostPosted: July 17th, 2017, 15:10
What is the problem with the drive ?
This should be a "native" MAXTOR and not "Seagate" so there is nothing that you can do with TTL to get your data back ...
Does the drive spins ? Does the drive clicks ? Does it makes starge noises ?
Does it provide full correct model name and capacity on BIOS ? What is the full model of the drive ?
PostPosted: July 18th, 2017, 2:32
It is Sabre family, native Maxtor. TTL is avilable via safe mode, it will help if there is a problem with SA.
PostPosted: July 18th, 2017, 15:37
I did never use TTL on maxtor ....
You can set Safe mode and load loader (or CPs) by ATA....
PostPosted: July 18th, 2017, 17:43
As I remember, to get into safe mode you have to send signal for initializing a safe mode, not a shorting a pins.
PostPosted: July 19th, 2017, 13:57
Jumpers ....
PostPosted: July 19th, 2017, 14:12
I think Martin is referring for SATA Maxtor drives.
www.pcimage.co.uk
PostPosted: July 19th, 2017, 16:27
Oh ....
The OP drive is IDE.
This is the first post :
PostPosted: July 19th, 2017, 16:33
Here :
http://www.hddoracle.com/viewtopic.php? ... t=80#p9619
http://www.hddoracle.com/viewtopic.php? ... =100#p9629
Some experimentation.
I can set safe mode and load from CPs on any MAXTOR as long as i have compatible FW or loader and heads are not damaged, etc ...
PostPosted: July 19th, 2017, 19:08
For Sabre family see pic how to connect wire for safe mode:
PostPosted: July 20th, 2017, 13:11
Yes, I forget that Sabre uses both types of PCB. Didn't work with ATA for a long time.
P.S. As I can see, Michel had provide short pins for SATA (hybrid) as well.
