 Post subject: SMART ERROR
PostPosted: August 1st, 2017, 21:05
all wd disks make this error when reset smart
i wrote 0021+0022+0023+0024 from alot of disks donor firm
no effects found
can i write any modules else
thanks
https://www.facebook.com/datarecoveryegypt
 Post subject: Re: SMART ERROR
PostPosted: August 2nd, 2017, 3:52
hi,
test all modules & see which are bad then rewrite with donor modules if its not critical modules..
http://www.lifeguarddatarecovery.com
PostPosted: August 6th, 2017, 9:34
THANKS FOR ALL
I MAKE IT
PostPosted: August 6th, 2017, 9:45
Ok !!!
Next time try with another tool as well like SeDiv or WDMarvel ....
Maybe this is happening because PC-3000 tries to clear logs as well as S.M.A.R.T. data/tables ...
PostPosted: August 7th, 2017, 8:36
this was from sediv
and i tried with mrt too
PostPosted: August 7th, 2017, 13:25
Damaged S.M.A.R.T. modules/tables with S.M.A.R.T. data or bad sectors on SA on the place where those modules are.
:D
Glad you did manage to get it sorted out.
