@chrisfoster, could you indulge my curiosity and show us what the Zip's file system looks like? If you connect it to a PC, you may be able to view sector 0 with a disc editor
Not sure what I'm doing, so if there are some options/utilities I should be running within DMDE?
LBA:0 block: 0
000: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
010: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
020: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
030: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
040: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
050: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
060: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
070: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
080: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
090: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
0a0: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
0b0: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
0c0: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
0d0: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
0e0: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
0f0: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
100: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
110: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
120: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
130: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
140: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
150: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
160: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
170: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
180: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
190: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
1a0: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
1b0: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
1c0: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
1d0: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
1e0: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
1f0: 42 41 44 20 42 41 44 20 42 41 44 20 42 41 44 20 BAD BAD BAD BAD
