 Post subject: Hitachi HDS VSP Firmware Flash (HUC106060CSS600)
PostPosted: August 9th, 2017, 10:01
Good Afternoon All,
I've recently come across a batch of Hitachi VSP 600GB 2.5" SAS Drives. (R5C-J600SS, 5541892-A, HUC106060CSS600, 0B25662)
Now these are 520byte sector size from the factory. However, unlike similar NetApp drives, they don't initialise correctly after being reformatted at 512 bytes.
I believe this to be a firmware issue, and so i'm hoping someone could help us out with a firmware file.
The firmware version on the factory drive is 'APAP'.
I have however seen the exact same HDS VSP drive working in standard servers (512 bytes) with firmware version 'FPFP'.
Would anyone be able to provide this file? It would be a huge help.
 Post subject: Re: Hitachi HDS VSP Firmware Flash (HUC106060CSS600)
PostPosted: August 9th, 2017, 15:34
The following article describes two methods to change the block size:
https://mikekuriger.wordpress.com/2013/ ... app-disks/
    sg_format --format --size=512 /dev/ice
PostPosted: August 9th, 2017, 19:41
That doesn't help i'm afraid. As stated above, I can change the block size but the drive will not initialise. I'm very familiar with changing the block size but this drive has something else preventing it from functioning in standard servers.
PostPosted: August 10th, 2017, 1:13
Sorry, I misunderstood.
PostPosted: May 11th, 2018, 11:23
Have you had any luck with these? I have the exact same drives with this issue.
PostPosted: February 28th, 2019, 4:18
Hi mates.
I recently purchased 8 similar drives on ebay, and reformat using SAS HBA works fine for me including drives with APAP firmware. However array constantly degraded in active usage unfortunately. I found Dell FW for these drives and going to try it today.
PostPosted: May 2nd, 2019, 21:11
I'm keen to know the result. I have the same problem, not initialized by windows disk manager.
PostPosted: July 25th, 2019, 22:10
Anyone got a solution to this as yet?
PostPosted: July 25th, 2019, 23:04
Hydata claims to, but don't bother going to their broken web site.
PostPosted: July 26th, 2019, 11:02
So anyway we can use these drive? Have 10 of them I bought off ebay :( :(
PostPosted: August 1st, 2019, 1:19
HYDATA gives the solution see the video
http://www.hydata.com\video\Hitachi\HUC1060xxCSSxxxSDF.mp4
File comment: Hitachi Superfirmware download tools
Users browsing this forum: Google [Bot] and 47 guests
