 Post subject: News for Marvel 88ss9189-bld2
PostPosted: September 5th, 2017, 10:33
Hi all!
I have here a SanDisk Ultra II
If i atach to Pc3k i get drive DRY, i can ID (model, serial capacity and FW). After that if I try to do anything Get nothing, always BSY.
for example If i try to read secs i get BSY led ON, and can not access to data.
main chip is 88ss9189-bld2
any way in this case?
Thanks in advanced
 Post subject: Re: News for Marvel 88ss9189-bld2
PostPosted: September 5th, 2017, 13:47
Power the drive off, then send the command to image. Does it read any sectors before getting stuck at BSY again?
RAID Data Recovery
PostPosted: September 6th, 2017, 8:42
Hi luke!
are you speaking about "DD" command on linux to make SSD image?
PostPosted: September 6th, 2017, 9:05
Are you not using DE with PC3K? Are you able to give me remote access?
RAID Data Recovery
PostPosted: September 7th, 2017, 5:00
no, i can not read any sec
as you can see on pic
Thaks
PostPosted: September 7th, 2017, 7:35
hhddrec wrote:
Hi all!
Thanks in advanced
probably "Translator issue"
PostPosted: September 7th, 2017, 14:14
yes very probably.
The question now is:
Do you think will be recoverable ussing pc3K for SSD?
any other way to recover translator?
PostPosted: September 7th, 2017, 17:07
Is it possible that SanDisk's Translate Sector (87h) ATA command has been retained in their SSD models?
If so, then this may provide a way to test the translator.
PostPosted: September 8th, 2017, 8:26
and how we can test?
PostPosted: September 9th, 2017, 3:51
hhddrec wrote:
yes very probably.
Do you think will be recoverable ussing pc3K for SSD? <<----Always read the latest updated news
<<----- Translator >> I dont think so , DATA >> Chip-Off (needs high skills)
good luck
PostPosted: September 9th, 2017, 6:13
deleted - answer for wrong model of Marvell
PostPosted: September 9th, 2017, 17:10
SanDisk CompactFlash Memory Card OEM Product Manual:
http://pdfstream.manualsonline.com/2/23ba20e9-6aaf-4f79-a7d9-f78379489686.pdf
There is a Translate Sector (87h) command on page 5-23:
When this command is issued, the controller responds with a 512-byte buffer of information on the desired cylinder, head and sector with the actual Logical Address.
Table 5-33 represents the information in the buffer. This command is unique to SanDisk CompactFlash Memory cards.
