I CAN SEE A LOT OF PROBLEMS WITH THIS ....
Hdd connecting with USB 3 port. I cannot see modules , tracks etc.
- You should use SATA if possible. If not you can try USB pass-trough or preferable TTL (ATA over TTL) to read modules and ROM. Target only the necessary modules as reading/writing by TTL is slow.
I find a strange method
Some HDD accept this method.
I making readonly with using windows diskpart.
- You should NEVER WRITE to a drive that you want to recover from even if it's just a boot sectors to make it un-mountable by windows.
This method mostly working busy mode hdd. Sometime raw hdd turning to NFTS directly.
- NO !!! On WD drives that are BSY (slow) patching module 02 and clear RE-LO are the best method to gain proper speed, NOT to mess with LBA space. AND WE DON'T EVEN KNOW IF HEADS ARE OK !!! For RAW/NTFS you are dealing at file system level and you should address this with software like R-Studio, etc lacking Data Extractor ... If you have MRT use Data Explorer to extract he data instead of messing with original bad drive (write to it).
But not solve busy mode.
- Of course NOT !
Anyway. I can see hdd family only with this method for this hdd. But i cannot see modules etc in MRT.
- Normal. How are you connecting the drive to MRT ? By .... USB ? If the drive is stuck in BSY you will have trouble with SATA even more with .... USB !!!
Or are you plugging the drive to the USB port of the computer and wishing that MRT do see the drive ?
It's allow DE but again very slow. I can see everything inside with windows. Same. Busy.
If you can see it with MRT DE at least you should have connected it to MRT somehew ... Most likely if you are using USB you can't send VSCs to the drive with MRT and that is why you can't see modules .... Assuming that you have some sort of adaptor to connect the USB drive by ---- USB ? To MRT ?
I tried tv9 tv10 circuit short. Windows not detect media. Says no media in device manager.
- This is 100% normal ! If you short those points firmware will not load and drive will not initialize. Of course windows will not see it.
I tried hot swap to Sata PCB . Nothing ...
- Can you explain EXACTLY what you have done here ? How did you ... HOT SWAP this one ?
Well ... and the list goes on ...
If you are making this sort of questions you shouldn't be messing with a client drive ....
