Forum rules
 Post subject: Make hard drives safer against firmware malware/rootkits ?
PostPosted: September 27th, 2017, 17:21
This is kind of silly but why won't :
1 - PC and Laptop makers don't allow for an option in BIOS set to ON by default to issue the security freeze lock to ALL hard drives as the PC boots up ? This is present in many laptops but could be extended to any PC with an option on BIOS to turn the feauture off. Windows (or other OS) could implement this as well.As soon as a drive is plugged to the system then Security freeze lock should be issued.
2 - HDD makers should REJECT the "Super ON" or any other Vendor Specific mode if Security Freeze lock is issued !!!
3 - If you want to access F/W on the drive you should move drive to a dedicated system with protection turned to off. On a regular system security freeze would be issued making hard drive unable to enter vendor specific mode and access to FW would be denied.
4 - If a computer were to be "infected" not only security erase wouldn't work but also attacks that would modify the hdd FW would fail.
:D :D :D
 Post subject: Re: Make hard drives safer against firmware malware/rootkits
PostPosted: September 27th, 2017, 23:16
Now you need to figure out how to do a FW update on such "locked" drive
https://www.linkedin.com/in/artemrubtsov/
PostPosted: September 28th, 2017, 14:22
You would need to temporarly allow for security not to be locked in BIOS, for example by allowing to boot for some time without sending the security freeze ?
PostPosted: September 28th, 2017, 16:59
I notice that the ATA standard allows the vendor to decide how the drive responds to the ATA Download Microcode command when in the security freeze locked state.
PostPosted: September 28th, 2017, 22:57
you cant even get people to not click on links like:
from commonwealth Bank Astralia <xibit99@gmail.com>
dear %USER
You mustplease cl ikc here to change your password or your account will be locked.
signed
security team
so why pay for a million dollar research team to get that sort of protection right.
with attacks like rowhammer, you have to invest a LOT to get something that is secure.
Users browsing this forum: No registered users and 0 guests
