 Post subject: Is this any good?
PostPosted: October 19th, 2017, 10:00
Just to dump the binary file from a TSOP48
https://es.aliexpress.com/store/product ... 69399.html
Was going to buy the flash extractor reader if not
Many thanks in advance!
 Post subject: Re: Is this any good?
PostPosted: October 19th, 2017, 17:20
Bad solution. For nand flash better buy Flash Extractor reader, it is quite cheap, but very good if you want only dump the memory and outsource it.
Odzyskiwanie danych
PostPosted: October 19th, 2017, 19:52
If you look at the chip support, it is mainly firmware type chips on IOT devices this may be suited for.. 2GB and under.
Also there is no data recovery software which is as important as the dumping of the chip. Agree with Arvika.
