 Post subject: Pensioner plugs wrong power into ex hdd
PostPosted: October 24th, 2017, 4:02
Thank you for reading my post.
As a newbie and possibly the oldest member here,i need help and advice.
having plugged my laptop power lead accidently into my Seagate external hdd i believe i have now have a dead HDD.
I managed to remove the drive from its casing and set it in place in my tower pc as a normal hdd.
i have done this before with a previous external drive with success.
as you probably figured,this time it did not work.
i am wondering if to try replacing the PCB? On the back of the drive itself,but unsure if this is the way to go.
If it is i am confused of the exact component to get,or indeed where from.
here is all the info i have
Seagate ST2000DM001
100724095
GTC18V-0?? C-1432=03-22 (Two digits i cannot read)
i am based in the UK England,so if its the last straw i will get it done by whoever you can recommend,but would very much like to try to fix it myself as a challenge.
thank you ...Fredrick
 Post subject: Re: Pensioner plugs wrong power into ex hdd
PostPosted: October 24th, 2017, 4:37
Im afraid its a bit more complicated than simply replacing the pcb... how technical are you?
PostPosted: October 24th, 2017, 6:25
pcimage.co.uk
PostPosted: October 24th, 2017, 7:39
Thank you for your reply,
I know how to solder,and my friend has a steadier hand,so good from there,
its just knowing the correct components to source
PostPosted: October 24th, 2017, 9:13
I'm 77 years of age. How old are you?
In any case, search for @fzabkar's posts about TVS diode and associated zero-ohm resistors.
Larry
PostPosted: October 24th, 2017, 10:52
Do you have multimeter to check TVS diodes and zero ohm resistor continuity?
Can you show us a pic (high resolution) of you pcb?
PostPosted: October 24th, 2017, 11:05
Larry
As possibly the second oldest member,i will look at fzabkar, thanks
PostPosted: October 24th, 2017, 11:07
Will do as soon as I can get hold of that star screwdriver and get it off the hard drive.
My friend has a multi meter,and will check.
I wont see him till sunday,so please bear with me all......thanks for all replies
PostPosted: October 24th, 2017, 17:48
Screwdriver is Torx T8 or T6 depending on screw size. You should be able to get at toolstation or somewhere like that.
https://www.toolstation.com/shop/p17579?table=no
<itch>
скратчи
PostPosted: October 24th, 2017, 18:34
Larry
Does how old you Feel count?
PostPosted: October 25th, 2017, 4:56
Does how old you Feel count?[/quote]
No it does not,i feel 21 inside,but still get up twice a night... :lol:
PostPosted: October 25th, 2017, 10:30
Easy tiger :)
<itch>
скратчи
PostPosted: October 27th, 2017, 12:45
Here we go
PostPosted: October 27th, 2017, 16:54
You have PM
PostPosted: October 27th, 2017, 17:18
How does the pc show it when connected via normal SATA ? Detects as something, or no detection at all ?
PostPosted: October 28th, 2017, 3:06
When fitted into my tower it shows nothing,no signs of life
I have another ex hdd that I did the same wrong power connection to (classic !!!)
but that did work in my tower once removed from its housing,but it was not a Seagate,i think that one was WD
PostPosted: December 15th, 2017, 14:06
Just an update.......
I sent the drive away to be repaired in the end.
Returned to me repaired,so I'm very happy.(no data lost)
Not sure if I am allowed to name companies,so please delete if needed.......
I used pcimage, up north.
Very helpful guys,good communication,and no hidden nasty surprises....recommended.
Users browsing this forum: Google [Bot] and 116 guests
