 Post subject: MHDD can't get it to run
PostPosted: November 4th, 2017, 15:21
I've tried 3 different MHDD boot CDs including most recent.
All I get is a win98 boot disk telling me HMA is not available then COMMAND NOT FOUND
Then General Failure WRITING DRIVE A
What am I doing wrong?
It's a newer Lenovo Skylake based workstation with 8GM of RAM.
Intel built in graphics (maybe that is messing with HMA?)
Anyhow I am trying to fix a messed up SSD and MHDD will not even run on this.
I am trying to follow these instructions:
However I'm stuck at mhdd not running at all.
And apparently because HMA is not available to it.
http://www.tested.com/forums/pc-and-mac ... tion-here/
 Post subject: Re: MHDD can't get it to run
PostPosted: November 5th, 2017, 10:34
MHDD knows nothing about the chipset of your laptop.
MHDD knows nothing about SSD either... :shock:
PostPosted: November 5th, 2017, 12:29
What? :shock:
Did you read the OP's link before commenting? Apparently not.
To the OP, try this instead:
https://askubuntu.com/questions/409684/image-or-reset-broken-ssd
PostPosted: November 5th, 2017, 18:55
Is the BIOS set up for legacy mode?
Hard Disk Drive, SSD, USB Drive and RAID Data Recovery Specialist in Massachusetts
Users browsing this forum: No registered users and 58 guests
