 Post subject: Introduction of MRT Data Recovery Software 2112 Version
PostPosted: November 24th, 2017, 5:00
Download link:
Online version:http://us.mrtlab.com/download/MrtEnSetups2112net.rar
Offline version:http://us.mrtlab.com/download/MrtEnSetups2112.rar
MRT 2112 version is coming. This version is chargeable.
Users will be able to update the software for free within one year after purchasing hardware. The date of this version is 171112, version number 2.1.1.2, installment package will be named by version number but not date.
Users of online version and offline version should download the corresponding installation package.
MRT 2112 version, version: 2.1.1.2
- This update is chargeable
- Add SSD utility (Beta)
Seagate F3, upgrade to: 2.0.1.7
- Add ROM reading and writing in LT,LM series
- Add firmware unlock of LT,LM series in the family ID of 5F,87,8C,A5
- Add firmware unlock of NM series in the family ID of 91
- Add virtual boot of family with ID 4F
- Add arbitrary head cut for 1CH series of 14 generation
- Add the support of loading LDR via serial port
- Add the support of modifying model for most HDDs
- Add head adaption of family with ID 72
- Support high baud rate when reading/writing ROM of family with ID 4F,55,59,76,7A,86,91,A5
- Add family panel (91,7A,A5)
- Add manually modify configuration file when reading/writing ROM under BootCode (In the MRT installation directory, the file name is SGT-F3GBootCodeBRF.ini)
- Optimize creating LDR incomplete issue of family with ID 56
- Add firmware unlock of family with ID 0x7A
- Rebuild head cut method of 1CH family
- Fix 03 module parsing problem of several HDDs
- Fix check error of firmware unlock mode I
Toshiba, upgrade to: 2.0.3.7
- Add family of HDWJ1 MQ01UBD
DE, upgrade to: 2.3.2.2
- Add HFS+ file system parsing, based on GPT and DOS partitions (Apple file system)
- Add function of creating compressed bitmap during data image (Range File)
- Add saving bad files separately and automaticaly
- Add support of mounting and file parsing of disk with capacity larger than 2TB
- Support mounting source disk with capaciity larger than 2TB
- Optimize GPT partition expansion function
- Optimize NTFS system parsing
- Add support to target disk of VHD type
- Add version number of DE task file
- Update MRT VIRTUAL driver, optimize driver transfer speed of disk with capacity larger than 2T
- Optimize HFS+ system based on GPT partition
- Optimize creating task file
- Optimize create head map function
WD utility, upgrade to: 2.2.5.5
- Add support for 1945, 1590, 1552 and other series in Boot ROM mode
- Optimize automatic detection error bug of few families in initialize self test environment function
- Add self-test extended tool for users familiar with self-test, can choose random combination process to do self-test
Samsung utility, upgrade to: 2.0.0.2
- Add default module list for all series; Optimize access to module list; fix an issue that T166(S) series family module list fails to be acquired
- Add support for M7E,M8E family in write burn resource function
- Add the function of search burn resources in write burn resource, can search according to model, firmware version, Part Number (this data is showed in start process), optimization function panel
- Add the function of using serial port to download resources (showed in resources download panel)
- Add the function of using serial port to write ROM (showed in ROM panel)
- Add "Start Burn-In test" function and "Continue Burn-In test" function of M7E family
Database, upgrade to: 1.0.1.7
- Solve the issue of database import failure caused by language code in multi-language system environment
SSD repair utility, version: 1.0.0.0 (Beta version)
- This tool is the initial version
- Include Samsung SSD utility, support Samsung 850,840,830 series.
- Include Intel 510 utility, support Intel 510 series.
- Include Marvell Controller utility, support SSD with Marvell Controller, such as Intel 320,710 series,etc.
Email: sales@mrtlab.com
Skype: sales@mrtlab.com
MRT Express & Ultra, Professional Data Recovery Tool
Email & Skype: sales@mrtlab.com
