 Post subject: Sediv WD Head Map ERROR
PostPosted: November 7th, 2017, 18:59
Hie ,I bought Sediv.When i try to detect WD disk ,I get Head Map Read-ERROR and Drive Table Read -ERROR.I tested with many working hard drives.Im learning HDD firmware. Please see attached pic
File comment: WD Head Map ERROR
 Post subject: Re: Sediv WD Head Map ERROR
PostPosted: November 8th, 2017, 6:15
I'm not familiared with Sediv, but you might need to set up in BIOS as legacy mode
there are definitely other forum members in here, who are familiared with Sediv who can answer better than me
PostPosted: November 17th, 2017, 10:16
no problem friend contact me for fix your problem
Company: ICCSYS
Email: iccsystem@yahoo.com
ICQ: 626146286
QQ: 2766349138
Mobile: 00201002359000
PostPosted: November 26th, 2017, 19:00
I would like to recommend ICCSYS for helping me to solve all my sediv installation.ICCSYS is very patient and was willing to help by remote desktop.Now my sediv is working.
But here is how i recommend how to setup sediv.
Steps (Do these steps consecutively when you want to activate)
1: Install windows 7 32 bit and activate .ensure that you fill USERNAME and REGISTERED ORGANISATION and COMPUTER NAME.**Do not install with username called "User" ,it will not work**
2: Install all you required drivers
3: Set screen resolution to 1280 x 1024 (if not available find it in custom resolutions for intel hd )
4: Install all your software which you may require before you create licence.lic.
5: Remove unnecessary usb devices
6:Shutdown and reboot from bootable flash of Hiren Cd with ghost software.
7: Create a GHOST image of the windows HDD and save .GHO on another HDD. (you can boot a live windows usb flash with ghost or use Hiren boot with ghost)
8: Restore the ghost image test if the Ghost image works.
9: If the Ghost Image is good then you can proceed to make Licence.lic for sediv and sehitachi.(keep the .GHO image safe)
10:Follow the normal way to email the .lic files and receive the activation files.
PostPosted: December 25th, 2017, 13:05
I would :
1 - Use XP 32 Bit instead.
2 - Use some sort of firmware tool hardware card even if it's obsulete PCI PC-3000 card. This will help allot if you have damaged drives that makes the system hang/re-boot. Even some "chinese" cards will do the trick ....
3 - Image the OS drive as stated. Run SeDiv and generate the license, when you have your dll files you want to backup that as well.
4 - You can run multiple versions of SeDiv and you can even run several SeDiv process at the same time. You can use those instances of SeDiv on diferent ports/cards to work with several drives at the same time.
Regards.
