Re: Is this BS?
September 26th, 2010, 1:47
code_slave wrote:"PCB circuit board cracked, transplanted faulty components to donor PCB and recovered all data."
Thanks I fixed the typo, "transplanted components to donor PCB and recovered all data" and the short answer is that it depends on the hardware failure.
SanDisks are always fun fun fun :)
-Jeremy
Re: Is this BS?
December 15th, 2011, 16:40
Zero Alpha wrote:http://www.recovermyflashdrive.com/flash-drive/SanDisk
Can this place really recover from sandisk hardware failures?
Sir ,
That Website Is Owned By Jeremby "sorry If i Mis Spelled His Name " .He is a Pro With Nand Flash Memories And One Of The Top Users Of Softcenter Tools And Thier English Support Specialist In USA .If I Am Not Wrong He Has also Conducted Some Classes For English Speaking People .
Re: Is this BS?
December 16th, 2011, 6:50
Sir ,
I agree. He is very active in Soft Center forum, he definitely knows his stuff.
Re: Is this BS?
May 29th, 2015, 15:23
As long as the NAND is intact and readable, it doesnt matter if controller is crypted or not. I've done many Sandisk NAND swaps with 0016x-x controllers. Works like a charm. Key is to have working donors for something like this.
Re: Is this BS?
May 30th, 2015, 19:14
grig85 wrote:Key is to have working donors for something like this.
& if u dont have a donor ?
Re: Is this BS?
May 31st, 2015, 5:18
Site from link does not work. Do someone have copy?
Jeremyb is owner of this site.
From my experience: I transplant many times controller or nand to other same working PCB, and NEVER works.
Many of information on DR websites is marketing BS.
Re: Is this BS?
June 1st, 2015, 22:02
arvika wrote:From my experience: I transplant many times controller or nand to other same working PCB, and NEVER works.
Maybe NAND was no good in your case, but it really does work.
Re: Is this BS?
June 1st, 2015, 22:09
on encrypted controller you would be out of luck then...
Re: Is this BS?
June 2nd, 2015, 5:26
Re: Is this BS?
June 2nd, 2015, 19:17
What Controller is it?
Encrypted SanDisk drives are usually 100% recoverable if you know what your doing unless the led blinks endlessly, sometimes you get lucky and it's a bad solder joint but usually the nand chip has been wiped or severely corrupted in those blinking led cases..
P.S: I love how a post about me is titled Is This BS..
Re: Is this BS?
June 2nd, 2015, 23:59
I just did the NAND swap on 20-82-00162-2 yesterday and it worked as usual.
Re: Is this BS?
June 3rd, 2015, 3:48
grig85 wrote:I just did the NAND swap on 20-82-00162-2 yesterday and it worked as usual.
20-82-00162-2 is XOR not AES like older SanDisk controllers.
Re: Is this BS?
December 6th, 2017, 20:58
Is NAND from controller 82-00263-1 encrypted?
Re: Is this BS?
December 6th, 2017, 21:09
labtech wrote:Is NAND from controller 82-00263-1 encrypted?
According to SoftCenter that should be an XOR. I'm pretty sure the 20-99-00128 models were encrypted.
Re: Is this BS?
December 7th, 2017, 9:32
Thanks. Sometimes I forget about the Soft-Center library. Long day.
Re: Is this BS?
December 7th, 2017, 12:24
labtech wrote:Thanks. Sometimes I forget about the Soft-Center library. Long day.
Well,
Time For Some Rest , One of The Best Libraries I Think
