 Post subject: Samsung HD 161hj
PostPosted: December 14th, 2017, 17:03
Drive spins perfectly no sound and clicking . not detecting in bios and in os
I suspected head is little bad
PCB BF41-0163A
I have another Hdd same model hd161j pcb BF-41 0154A
both head match?
 Post subject: Re: Samsung HD 161hj
PostPosted: December 14th, 2017, 17:07
“No sound” AND “ and clicking”?
Which is it?
PostPosted: December 14th, 2017, 17:18
I mean spins continuously samsung HD161HJ
second one is working fine
PostPosted: December 14th, 2017, 18:07
Post terminal output, these normally click if heads are bad.
PostPosted: December 15th, 2017, 17:28
Nothing in terminal (blank)
Marvel Chip is getting more heat
PostPosted: December 16th, 2017, 5:03
Are you sure you're connecting terminal correctly?
I've never seen a Samsung drive producing blank terminal.
WD Trusted Partners
PostPosted: December 17th, 2017, 12:54
I have checked again connections
i removed pcb and checked pcb with power still it getting marvel chip getting heat
may be marvel chip damaged
PostPosted: December 17th, 2017, 16:41
What are the voltages at the Tx/Rx terminal pins? Perhaps your client has damaged the UART port.
PostPosted: December 17th, 2017, 16:59
Just to be sure, have you tried terminal connection in the other hdd of the same model you have, and it worked ?
PostPosted: December 18th, 2017, 5:24
You are right Sir
I checked with multi meter RX/TX ports shorted 0 ohm
PostPosted: December 25th, 2017, 16:38
Are you checking the correct RX/TX pins ?
Did you try to gain TTL access with a known good drive ?
:D :D :D
PostPosted: December 26th, 2017, 14:08
:D :D :D
yes sir
I have carefully checked Rx/TX ports and both ports short and voltages same on both ports. i.e 0.43
finally I got SA access got some data it has more unreadable sectors now the drive is completely closed. some other data also there to recover
PostPosted: December 26th, 2017, 14:58
:shock: :shock: :shock:
What tools are you using to gain SA/MC access ?
What do you mean by drive completly closed ?
If you have user area access most likely firmware is ok ....
PostPosted: December 28th, 2017, 14:50
What do you mean by drive completely closed ?
yes sir Firmware is ok
I changed pc Now drive detected via sata to usb and I formatted C ( No important data) . Now it detected Bios( directly connected to pc)too. I have seen two partitions become Raw and one partition shows NTFS (D Drive)but if I open any folder access denied error. I f i checked Checkdisk it deleting entries in ( $130)
PostPosted: December 28th, 2017, 16:21
Doesn't sound good at all ......
Users browsing this forum: ddd123 and 68 guests
