 Post subject: Seagate F3 ST31000528AS ABR error
PostPosted: December 26th, 2017, 2:58
Hello Sir,
Seagate F3 Pharaoh 1TB disk and model: ST31000528AS spinning well shows id details also. But in data extractor "Error - Set UDMA = UDMA133" this error comes.
Terminal messages are given below:
Rst 0x20M
(P) SATA Reset
PASS
RW: Error processing Performance Parameter File: 203C
Send Status: COMRESET seen
Starting LBA of RW Request=74706DAF Length=FFFFFFFF
ProcessRWError -Read- at LBA 74706DAF Sense Code=C3160080
FAILED to spare!
FAILED to spare!
InitiateMarkPendingReallocateRequest for disc_lba: 74706DAF
FAILED to spare!
and 3 status registers shows DRD,DWF, DSC and in error register ABR shows at time and T also not getting.
In sector edit not accessing sectors because of ABR error...
How to solve this problem???
 Post subject: Re: Seagate F3 ST31000528AS ABR error
PostPosted: December 27th, 2017, 6:02
CLEAR glist and smart then reset hard disk and give transltor
203 eroor is normal
PostPosted: December 28th, 2017, 6:13
Thanks for reply..
I did clear g list and SMART and translator regeneration.
Now disk has clicking sound.
and still in terminal same message shows as follows:
Rst 0x20M
(P) SATA Reset
PASS
PostPosted: December 28th, 2017, 16:17
ST31000528AS = 7200.12 = Those very nice drives with non-resident G-List entries that end up with partial access only when you regen translator the wrong way .....
Hope that you did backup the firmware first !
Initial problem was related to sectors marked as pending. You could probably bypass that by disabling relocation.
I don't think that clearing the G-List and regening the translator was a good move ....
Time to send the drive to someone with PC-3000 and more experience with those drives ?
PostPosted: December 30th, 2017, 10:22
203 eroor is normal
Well,
Its a issue with reallocation of media Cache ,You people have a habit of doing smart clear clear glist and translator for every case that comes your way ,This is absurd .In Every forum you are advising people to do this without using 1% of your brain ,Before you clear smart you should first check if indeed thats a issue ,Ditto with glist and translator ,you people are funny .
Users browsing this forum: MSN [Bot] and 21 guests
cron
